[Z06] exhaust tips carbon removal tip
Old 07-07-2013, 09:29 AM
olf dog
olf dog's Avatar
Default exhaust tips carbon removal tip
I always use to use metal polish to get the carbon off my exhaust tips until now. Dont get me wrong polish works great to bring them to a luster, but is slow to remove the stubborn carbon. I now use the same product I use to clean carbon from my firearms. It is called bore tech c4 carbon remover. I just put some on a rag and it just wipes it write off almost instantly. You can buy it from many online distributors. Give it a try and let me know what you think.
Old 07-08-2013, 11:06 AM
JetMechZ16
JetMechZ16's Avatar
Can it be used on a C5???
Just kidding, sounds like a good idea. Do you think any bore cleaner will work? Since I have some other types for my guns, I may try them first.
Old 07-08-2013, 12:24 PM
envyz06
envyz06's Avatar
Sounds interesting, might have to try and picks some of this up.
Old 07-08-2013, 12:54 PM
Scooter70
Scooter70's Avatar
Hmmm.... Think Hoppe's 9 would work?
Old 07-08-2013, 01:11 PM
racebum
racebum's Avatar
usually just use 800-1200 grit wet/dry when i'm washing the car
Old 07-08-2013, 01:13 PM
bob22z06
bob22z06's Avatar
I use mothers brand chrome polish....it works great for me ...I put it on let it dry then let it dry and wipe off...result as good as new...
Old 07-19-2013, 06:41 PM
olf dog
olf dog's Avatar
ttt
Old 07-19-2013, 07:23 PM
Supercharged111
Supercharged111's Avatar
That's great if you're not 110,000 miles behind the curve already. . .
Old 07-19-2013, 07:44 PM
knr13
knr13's Avatar
i use WD40 works great 135k and going strong !
Old 07-21-2013, 08:35 AM
fxdl
fxdl's Avatar
wd40. I'm finding more and more uses for that. I now use it to kill wasp nests. Works great and cheaper. I discovered it is the best thing to prevent acid build up on battery terminals.
Old 07-22-2013, 11:25 AM
bob22z06
bob22z06's Avatar
I use wd40 on outdoor stainless steel grills and appliances works great , better than any stainless steel cleaner..
Old 07-22-2013, 12:25 PM
YYZ06
YYZ06's Avatar
I've been using good, old fashioned, Bar Keeper's Friend powder and a Scotchbrite pad. I'll have to give WD40 a try.
Old 07-23-2013, 12:41 AM
knr13
knr13's Avatar
what i use is still wool with the WD40 BUT you need to make sure you use nothing lower then a 000 work great on chrome wheels as well just water and wool 0000 with lite to med pressure
http://www.walmart.com/ip/22949331?w...599990&veh=sem
Old 07-23-2013, 08:24 AM
YYZ06
YYZ06's Avatar
It is not a good idea to use steel wool on stainless steel parts. The abrasion removes the protective passivation layer on the stainless steel and the wool can embed steel particles and cause the stainless steel to rust. I'm not saying that if you use steel wool you WILL rust your stainless steel parts but why risk it when there are good non-ferrous materials such as Scotch brite or a brass pot scrubber to use on your stainless steel parts. Chlorine based abrasive cleaners (such as Comet) are also not good for stainless steel.
Old 07-23-2013, 10:44 PM
knr13
knr13's Avatar
read the chart i have been using this for years (0000 and 000) on SS and other's
To exhaust tips carbon removal tip
Quick Reply: [Z06] exhaust tips carbon removal tip
