Seat Belt Brake
Old Jul 7, 2013 | 11:27 AM
Baetke's Avatar
Baetke
Default Seat Belt Brake
Notice my seat belt does not grab when I pull on it hard. Any one have a fix for this problem. Guess in a bad hit the belts are not worth much use this way. Thanks
Old Jul 7, 2013 | 12:21 PM
bumble-z's Avatar
bumble-z
You are meaning the seat belt, not the shoulder belt?
Old Jul 7, 2013 | 02:21 PM
Baetke's Avatar
Baetke
sorry, I meant the shoulder belt.
Old Jul 7, 2013 | 08:44 PM
KDG1999's Avatar
KDG1999
Default seat belt
When you go to put your seat belt on, pull it out all the way first. Then fasten it and let it retract.( For spirited driving only). Look in the owners manual and it will tell you this. There is a lot of info in the owners manual. Mine stays in the glove box to refer to when needed. To test your shoulder belt out, it should hold you in place when you step on the brakes. Someone correct me if I am wrong.
To Seat Belt Brake
