[Z06] Roller damage 02
Old Jul 7, 2013 | 05:43 PM
Matlockssix's Avatar
Matlockssix
Cruising
Default Roller damage 02
The passenger roller is bent. Can't tell if it is part of the frame or if it is attached to a bracket.. Is it something to be concerned with even know the roller still operates?
Old Jul 7, 2013 | 05:54 PM
Matlockssix
Cruising
Front of the car passenger side.. There are 2 rollers as you know the driver side is straight but the passenger side is bent/ leaning over about a 1/3 of the way.. I am trying to get pic
Old Jul 7, 2013 | 06:19 PM
bumble-z's Avatar
bumble-z
These frame savers?
http://www.customcorvetteaccessories...fattmamma.html
Old Jul 7, 2013 | 06:23 PM
Matlockssix
Cruising
Yes thanks I believe that answers the question of being bolt on or not.. I may have to straighten the bracket that those attach to before I install the double rollers.. Apreciate the help and link!!
Old Jul 7, 2013 | 07:43 PM
Matlockssix
Cruising
Old Jul 7, 2013 | 10:12 PM
Justinduhhhh's Avatar
Justinduhhhh
holy **** what did you hit
Old Jul 7, 2013 | 10:21 PM
Matlockssix
Cruising
Not sure it was like that when got car, after further inspection the only thing I see is the 1" square tubing a little beat up about 6" both ways from the roller.. Am I screwed or can a shop cut out the bad section and reeled in new piece?
Old Jul 7, 2013 | 10:23 PM
Matlockssix
Cruising
Old Jul 7, 2013 | 10:25 PM
Matlockssix
Cruising
Reweld
Old Jul 7, 2013 | 10:46 PM
Justinduhhhh
so the roller is welded on ?
the square tubing doesnt look that beat up just looks like a ****** weld job
Old Jul 7, 2013 | 10:50 PM
Matlockssix
Cruising
Yea the rollers are welded on on both sides, the tubing is a little hammered up..is it worth messing with in your opinion?
Old Jul 7, 2013 | 11:05 PM
Justinduhhhh
if your **** you can cut and reweld it
my rollers bolt on to the square tubing and have 2 rollers on each side
u can probably cut it out clean it up and clean the square tubing if you would like
is there any other underdamage?
Old Jul 7, 2013 | 11:17 PM
Matlockssix
Cruising
Does not look like anymore damage. Thinking it got popped on that side but it all looks fine except for that roller and short portion of tubing, I might have both sides cut out and done right because the rollers are supposed to be bolt on like you said
To Roller damage 02
