So 5 months ago. i bought a 04 z06 with 26k miles.
First week i would get that rotten egg smell. Googled it and first thing i thought about was gas.
Went away.... Mostly use 91.
Here in northern california it has been 100+ easy lately. 90+ right now.
I have been getting on the car a little hard more and more since im getting used to it. Nothing to serious but i have been noticing the temperaure above 220 a lot. If i get on it for more than 5 min i get that rotten egg smell again also.
An ideas?
Car is completey stock to my knowledge. Was thinking about a callaway CAI and 160 tstat. Along with a tune from tps.
Those temps normal especially i your 100 deg temps outdoors. I highly recommend you send off for an ECU tune where they will adjust Fans and you can swap to 160 deg T Stat. $150 best money you'll ever spend
Could i also get a dyno tune to do this? Or is an ecu tune almost the same thing? Which is better?
WHo does ECU tunes?
Yes they both do the same. A dyno tune done by a good tuner is probably best but will cost more. For a basically stock car with an intake and tstat a mail order tune would work well and save you a few bucks. ECS would be my suggestion for a mail order tune.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Thank you! OP, here is a link to our tuning special.
