Mileage Light
Old Jul 13, 2013 | 01:29 PM
tcomann's Avatar
tcomann
4th Gear
Default Mileage Light
My mileage light does not come, but everything else does. Read my book and nothing in it. Any help Please
Old Jul 13, 2013 | 01:56 PM
65GGvert's Avatar
65GGvert
What's a mileage light?
Old Jul 13, 2013 | 02:07 PM
VETJAZZ's Avatar
VETJAZZ
Old Jul 13, 2013 | 02:13 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I was wondering the same thing.
Old Jul 13, 2013 | 02:19 PM
Mickeyrx70's Avatar
Mickeyrx70
Low fuel light??
Old Jul 13, 2013 | 10:18 PM
Looks like you are going to need to be a lot more specific on exactly what you are asking about.
Old Jul 13, 2013 | 11:06 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Please post a picture of the light that doesn't come on.
Old Jul 14, 2013 | 12:41 AM
o2bnkc's Avatar
o2bnkc
Mileage light doesn't come.....Hmmmm, no I won't go there.
Old Jul 14, 2013 | 12:44 AM
o2bnkc's Avatar
o2bnkc
While I'm on it, don't schools teach kids how to structure a basic sentence anymore? Good gravy!
Old Jul 14, 2013 | 01:23 AM
Mr.Bill's Avatar
Mr.Bill
No, Because someone might get offended.
Old Jul 14, 2013 | 10:37 AM
Avaric3's Avatar
Avaric3
lmfao hilarious, but unfortunately it's true with the way this country works today.
Old Jul 14, 2013 | 04:19 PM
WetteVette's Avatar
WetteVette
Maybe he means the DIC displays everything except the mileage?
Old Jul 14, 2013 | 05:02 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Gotta love this forum for its entertainment value.
Old Jul 14, 2013 | 07:10 PM
o2bnkc's Avatar
o2bnkc
Got to agree with that!
Old Jul 14, 2013 | 09:42 PM
Hope we didn't scare him off - would like to know what this light is he mentioned though.
Old Jul 17, 2013 | 07:36 AM
tcomann's Avatar
tcomann
4th Gear
Default Dic light
All lights come on my dash. BUT when you look at the DASH IF you can see that far, it will show the mileage also and none of the DIC lights come on also. SO for you older guys who know everything what is the cause
Old Jul 17, 2013 | 07:40 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Personally, I'm offended by the term good gravy.
To Mileage Light
Old Jul 17, 2013 | 07:57 AM
Phanni's Avatar
Phanni
When you unlock your car using the remote, the mileage display will light on the DIC. It goes out when you open the door. The second way to display the mileage is to push the "trip" DIC button (#3 button) until odometer appears on the DIC. That information is all somewhere in the car's manual.
Old Jul 17, 2013 | 09:20 AM
3sACROWD's Avatar
3sACROWD
Your description still isn't very clear BUT I think what you are saying is that all of the dash lights seem to work when you turn the key on with the exception of the DIC display.
So, we start with the easy things first.
1) With the key on, try depressing any of the DIC buttons to see if you get the DIC to display some information. (You can have the DIC set to display nothing so this is why I suggest this step first.)
2) Check all of the DIC buttons to see if any of them are stuck in the depressed position.
3) If 1 and 2 fail, you have have to take the IPC (Instrument Panel Cluster) out to troubleshoot further. The DIC buttons are wired to the IPC directly. The IPC provides the 5 volt power for them, and is also the ground for the buttons. There ia a multi-color wiring bundle from the IPC to the switches. You will have to remove the IPC and see if the connector has come loose. If it is not loose, then you need to check between the GREY wire (ground) and any of the others and see if you get 5 volts across them. If you don't get 5 volts, the IPC needs repair/replacement. If you get 5 volts, then the switches themselves are bad. If I had to guess one of the switches has "jammed" as if you were holding it down constantly, and the other switches aren't functioning due to that one. (information for step 3 copied from a post by 8VETTE7)
4) Don't be such a hot head. You're new to the forum, your post was unclear, people on here are helpful if you're willing to communicate clearly and listen, and they like to have fun.
Old Jul 17, 2013 | 09:57 AM
ztheusa's Avatar
ztheusa
Or just turn on your parking lights.
