[Z06] Trunk Partition
Old Jun 27, 2002 | 05:56 PM
Tom Steele's Avatar
Tom Steele
Default Trunk Partition
Hey,
I'm thinking about making my own, and saw some of the ones offered on the net.
Seems like I could make one that ISN'T heavy, fill it with dynamat or something similar and have a good noise dampner without as much weight.
Any suggestions on whether any of the commercial ones are really good enough not to bother with making my own?
Old Jun 27, 2002 | 08:23 PM
JeffMc's Avatar
JeffMc
Default Re: Trunk Partition (Tom Steele)
Tom,
I made mine with:
- 1" pink foam board (that they use as installation in houses forgeting what it's called)
- Black Marine carpet from Lowes
- 3M Spray adhesive
- Duct tape.
(Around $25 total).
I measured the lengh and height them cut it in half. Got the right side to fit using a utility knife. Then used it as a template for the left. Taped them together in middle and carpeted.
Less that 2 pounds. Easy to pull down and push back (one handed) to lay crutches in the back. You can do a lot more... but this works great for me and looks good.. Cools/Heats faster and quieter when you want it to be.
- JeffMc
Old Jun 27, 2002 | 08:36 PM
JeffMc's Avatar
JeffMc
Link for additional info:
http://forums.corvetteforum.com/zerothread?id=178942
To Trunk Partition
