[Z06] Active Handling with no codes
Old Jul 17, 2013 | 04:04 PM
jrnardi's Avatar
jrnardi
Default Active Handling with no codes
My 03 Z06 with 54K miles is intermittently displaying the Active Handling message. It happens when I'm doing normal street driving. No sharp turns and constant throttle.
Using a Snap On computer I can't find any codes.
Any suggestions?
Old Jul 17, 2013 | 04:19 PM
Oleman's Avatar
Oleman
You can access all of the code history in the DIC, you do not need a reader. If it is like most of these through the years the module may be failing. Mine did on my 01, did pretty much same as what you describe here.
Old Jul 17, 2013 | 05:16 PM
jrnardi's Avatar
jrnardi
Default Active Handling no codes
I tried the DIC first - no codes there either. What module are you referring to?
Old Jul 17, 2013 | 05:45 PM
badass7's Avatar
badass7
Believe it or not, check your grounds in engine bay. Just clean and it will eliminate those pesky codes. It has worked for me.
Old Jul 17, 2013 | 09:12 PM
Oleman's Avatar
Oleman
See post #66 in the C5 Tech DIY section it is all explained there.
To Active Handling with no codes
