very low idle
Old Jul 17, 2013 | 05:40 PM
kikicorvette's Avatar
kikicorvette
Default very low idle
hello
when i leave home, after one or two kilometers, I stop in an intersection,my idle drops at 500 rpm and rises back to 750 when I really stop;
it's very low and I feel like she will stall but she does not .
I feel it is getting worse
what it could be ?
thanks for your help
excuse my poor english
Old Jul 17, 2013 | 06:24 PM
Bent98c5's Avatar
Bent98c5
My tach shows 500 at warm idle. It'll go up to the 750 in park or n
Old Jul 17, 2013 | 07:28 PM
PryOpenUr3rdEye's Avatar
PryOpenUr3rdEye
Does it surge at all? Sluggish when starting to move?
Old Jul 17, 2013 | 08:56 PM
Bent98c5's Avatar
Bent98c5
Nope not at all. I just drove it and I do have to say it was more like 600 rpms not 500. But it runs great
Is your mpg gone down a lot lately? How clean is your air filter? What have u checked and when was your last tune up
Old Jul 18, 2013 | 04:17 AM
kikicorvette
mpg is about 11,5 L/100
my air filter has been changed last summer but i'll check it this morning
Old Jul 18, 2013 | 04:45 AM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Something else to look into is the throttle body. At ~60-70k I had to have mine cleaned, just some throttle body cleaner spray picked up at the local parts store. It made the difference between an A4 stalling just sitting at a stop and running smoothly.
Old Jul 18, 2013 | 02:03 PM
kikicorvette
my air filter
throttle
after i clean it
maf
i'll try tomorrow
Old Jul 18, 2013 | 02:12 PM
David Shiel's Avatar
David Shiel
Default My A4 idled normally when hot at about 500.
Now, after performance tuning, it sits at about 550 in Drive. Seems quite adequate and normal.
Old Jul 18, 2013 | 03:29 PM
3sACROWD's Avatar
3sACROWD
Does your car have an automatic or manual transmission? If manual, does the RPM raise to 750 after you push the clutch in and come to a complete stop? You may be slowing down in a gear that is too high for the speed and you're lugging the engine below the normal idle RPM. This is more noticeable when the engine and transmission are cold. Now that you are watching for this condition, you might be noticing it more even though it was happening all along. You wouldn't be the first person to do this. If this is the case, you can either choose a different gear, push the clutch in sooner, or ignore it.
If I did my conversion correctly, your fuel use looks ok. I'm estimating you're getting ~19.8 MPG. I'm assuming you do quite a bit of in town stop and go driving. Have you noticed a change in fuel use?
Old Jul 18, 2013 | 04:20 PM
kikicorvette
It s a 6 speed.
She has 112500 miles and i own her for 5 1/2 years.
When i slow down i press on the clutch pedal
and when i m almost stop the idle drops at 500 and
even below.
I think it s not normal cause she did not do
this before. The idle never dropped below 750.
This appears a few weeks ago.
Old Jul 18, 2013 | 04:42 PM
Lee DeRaud's Avatar
Lee DeRaud
I'm seeing 500 consistently on my A4...just assumed that was normal for this size/type engine.
One odd thing is that I've looked everywhere obvious in the service manual(s) and cannot find any specification for idle speed. Seriously?
Old Jul 18, 2013 | 06:53 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Idle RPM is controlled by the ECBM computer. "Normal" for any LS engine is 750 RPM after the engine is warmed up. The engine should run around 100 RPM higher until it is warmed up. When you turn on the AC compressor the computer bumps your idle up about 50 RPM to compensate for the increase in load.
OP, since your car is not running in this manner and no changes in the computer program has been made then you must have a mechanical reason for the change in behavior.
Air filter, dirty fuel injectors or a bad one, dirty mass air flow sensor, bad spark plug or spark plug wire or a combination of all of these might be the culprit.....even bad gasoline
I am no mechanic but I would eliminate the possible causes and go from there.
p.s. Your english is WAY better than my Swedish!
Old Jul 18, 2013 | 07:59 PM
hklvette's Avatar
hklvette
I've got another cause: faulty Intake Air Temp sensor or wiring. My C5 had the same behavior, and starting throwing IAT codes after a while. The cause was a broken wire going to the IAT. Hard to find, as the insulation was still intact. If you can get your hands on a scan gauge, that makes diagnosing the problem a LOT easier.
Old Jul 18, 2013 | 09:52 PM
CQRT's Avatar
CQRT
vacuum line off or leaking ?
(the small black hoses that run all over)
Good luck!
Old Jul 18, 2013 | 10:21 PM
El original's Avatar
El original
I had same issue low idle and it was the air filter. I replaced it and after about two days it now idles at 750-800 rpm. It took a couple of drives before the idle recovered. Also some sea foam fuel additive is a good idea. Good luck, Rob
Old Jul 19, 2013 | 02:26 PM
kikicorvette
good news
Yesterday I cleaned the throttle body who was a bit dirty, and also cleaned the MAF and air filter.
this morning on my way to work, my vette has run perfectly. cold idle at 1000 rpm and after heating at 750-800 rpm
thank you all
I speak french
Old Jul 19, 2013 | 05:10 PM
Lee DeRaud's Avatar
Lee DeRaud
That's what I expected to see and I'm more than willing to believe it's true, but do you have an actual reference for that number?
As I said, I can't find anything in the service manual, even under the section for diagnosing "bad idle".
To very low idle
Old Jul 20, 2013 | 02:15 AM
o2bnkc's Avatar
o2bnkc
I speak french [/QUOTE]
Me too! " I SURRENDER! " That's about all the french I know.
Old Oct 11, 2013 | 10:17 AM
AlsC5's Avatar
AlsC5
I just cleaned the throttle body last night. Wasn't too dirty but since I haven't done since I bought the car 5yrs ago thought it was time to clean it.
After cleaning it and driving this morning I noticed the rpm's were a bit high, around 700-750 in park and on D around 500-550. Also noticed that when slowing down at about 600 it does a quick jump to 700-750, which It never did before. Engine is basic stock just for the Vararam and XS Power headers and X pipe and mail in tune. (automatic trans)
Can anyone tell me if this is normal after a TB clean? What can I do to stop that quick rpm jump?
Appreciate any input.
Old Oct 11, 2013 | 03:59 PM
El original
All the rpm numbers are normal operation but the jump is questionable. Is the air conditioning on or off? Try turning it off if it is on and see if there is any difference. I think it is a rpm bump to maintain AC pump drag. Good luck, Rob
