[Z06] C5 Rim size
Old Jul 19, 2013 | 10:59 PM
bear101's Avatar
bear101
4th Gear
Default C5 Rim size
I am sure this has been written many times. Can I run 18" front 19" rear on my 2002 Z06? Can't seem to find a good, if any 17" 18" tires!! Want to run 305's on rear! Any help works.
Old Jul 19, 2013 | 11:15 PM
Supercharged111's Avatar
Supercharged111
Nitto NT01s can be had in the 305 flavor now for your factory 18s.
Old Jul 20, 2013 | 03:42 AM
MonolithMonolith's Avatar
MonolithMonolith
I'm going to be running 18x9.5 up front, with 275-35-18's, and will be running a 19x11 in the rear, with 305-30-19's up front. It's important for you to have those sidewall sizes if you run an 18/19 combo so the total wheel diameter is the same, and your Traction Control System won't get all messed up and speedo won't get off, etc. I bought Bridgestone Potenza Pole Position S4 tires. Haven't mounted them yet, but the price was right and they got good reviews.
Old Jul 20, 2013 | 07:39 AM
bear101's Avatar
bear101
4th Gear
Thanks. Will go and check them out.
To C5 Rim size
