Hurst Shifters
Old Jul 21, 2013 | 07:15 PM
slsnider423's Avatar
slsnider423
Default Hurst Shifters
Hi folks. I've purchased a used Hurst shifter for my 2004 C5. Perhaps I'm suffering from "buyers angst" but I'd love to hear from Corvette owners who have installed a Hurst shifter. Does it make a difference? Was it worth it? Thanks much!
Old Jul 21, 2013 | 11:12 PM
silver408z's Avatar
silver408z
I have a hurst in my car. I am very happy with it. Was a huge improvement over the stock shifter. I do not have experience with other shifters. A lot of times people talk about what ever shifter is in their car and that its the best. Maybe there are better ones than the hurst but I am happy with it.
Old Jul 22, 2013 | 09:13 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Must be the season for Hurst shifters. I found one at a good price and had to buy it. I don't have mine installed yet either, so I am hoping to hear more feedback too.
Old Jul 22, 2013 | 10:29 PM
El original's Avatar
El original
Just install it and then tell us how much you love it and can't live without it...etc. Its not a big job/expense.
Old Jul 27, 2013 | 10:41 PM
slsnider423
I installed my Hurst shifter today. I haven't had much practice disassembling interior panels, but I got through it without breaking anything! The Hurst is much stouter than the stock shifter and offers shift stops and "side to side" tension adjustments. Very nice! After everything was installed and back in place, a test drive was in order. I found that the shifts were very positive - I knew when I was in a gate - but it took a bit more effort to make a shift. No problem with that - good tradeoff for not missing a gear. I probably will do a few more adjustments - it took a bit of searching and extra "pulling" to find 6th gear. All in all, I'm glad that I made the purchase.
Old Jul 27, 2013 | 11:18 PM
TEXHAWK0's Avatar
TEXHAWK0
Hurst is a little harder to get into first gear, but with the sping loaded gate, all you do is push the shifter forward for the 2nd to 3rd shift and it will always hit 3rd without having to guide it.
Take time to trim the factory rubber boot to fit the base, and it will eliminate any noise and heat. A heavy, solid **** will eliminate most vibration that some people get.
The biggest problem with installing the new shifter is being able to get the factory **** off if your car still has the factory shifter.
Old Jul 28, 2013 | 01:58 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
The stiff shifting can be adjusted by removing the small springs. I'm using just the large pair. I think you also back out the gate adjusting screws altogether. They're not needed. I also realigned the center with the 1/8th inch pin. The noise was an issue because of the big hole in the shifter boot. I bought a rubber plug at ace hardware and drilled a 1/2" hole in the center. Slid it down the shaft wide end down then used a zip tie around the boot to secure it to the stopper. No more noise. Mine came attached to a zo6 lower box. It has steel bushings instead of rubber. Much firmer shifts
Old Jul 28, 2013 | 07:25 AM
Vinny 2001's Avatar
Vinny 2001
Form reading it seems many of the aftermarket shifters all have this in common. Can't say it's 100%.
Old Jul 28, 2013 | 08:13 AM
mikeyrko's Avatar
mikeyrko
I have a Hurst in my car I'm getting ready to sell it as soon as I find a C6 shifter. I think it's a good shifter but not for me.
Old Jul 28, 2013 | 08:44 AM
StatmanRN's Avatar
StatmanRN
It takes a bit of getting used to - fairly high effort and notchy. Search the Antivenom mod- helps a lot. I used one washer.
Old Jul 28, 2013 | 12:25 PM
johnson-rod's Avatar
johnson-rod
I've had a Hurst for several years. I agree with and have done all the recommended stuff above.
1) Use the Hurst ball-No rattles, not cold or hot and very cool
2) Only use the outside springs
3) Anti-Venom
4) AMSOIL Severe Gear
5) Correct alignment
6) Keep it clean and greased
7) Put back the rubber gasket - cut it or turn it upside down
8) Don't forget to put the decal under your hood
Hurst shifters and Corvettes go together like peas and carrots.
Old Aug 15, 2013 | 05:07 PM
TEXHAWK0's Avatar
TEXHAWK0
If you like the retro look of the rectangular chrome stick with HURST name down the side, Core Shifters now makes a base that will bolt to the Hurst stick...
Old Aug 15, 2013 | 05:11 PM
cmark84's Avatar
cmark84
3) Anti-Venom
So removing the inside springs will reduce the stiffness?
Old Aug 15, 2013 | 05:32 PM
Sinister-one's Avatar
Sinister-one
You should have purchsed an MGW shifter.
Old Aug 15, 2013 | 07:35 PM
AZCE's Avatar
AZCE
I personally don't like how stiff they are and would much rather run a C6 Z06 unit with a shorter shaft.
Old Aug 16, 2013 | 05:56 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
You can't blame notchiness on the shifter. Out of the car it flops around. There are no gates in a Hurst shifter, or stock shifter, all any corvette shifter does is move a rod that goes back to the rear mounted transmission, like old vw's. The gates and notchiness are in the tranny. The anti venom mod reduces the pressure on the detent ball giving you easier shifts.
Old Aug 16, 2013 | 04:47 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
From what I'm reading they're about the same. Notchy unless you do the anti venom mod.
2nd to 3rd straight forward. It took me a few tries to make that happen with ease as I wasn't used to it.
What I don't like about an MGW is going from 3rd to 2nd. Better be careful or you won't get it in gear.
I need to do the anti venom mod and maybe I would like it better. It's not bad, but not up to my standards either. Better than stock I'm sure but I have nothing to compare it to as mine came with the MGW.
To Hurst Shifters
Old Aug 25, 2013 | 12:53 PM
Sinister-one
Never had any problems with my MGW. AND I prefer it BETTER that the Hurst.
Just my.02...
Old Aug 25, 2013 | 01:55 PM
3318C5's Avatar
3318C5
Had the Hurst for 9 + years & have never had an issue. I don't mind the little extra effort to go through the gears & the Anti-Venom mod takes care of this if it is an issue for you.
Overall a great product that improved driveability in the car (vs the sloppy stock shifter).
Old Aug 29, 2013 | 09:25 PM
TEXHAWK0's Avatar
TEXHAWK0
I had the Hurst billet shifter in my 2004 Z06 for almost 10 years, and just changed it to go to a custom shifter with the Hurst bolt on stick and no extra spring loading.
I measured the throws, and it is the same as the Hurst short throw shifter and the C6 stock shifter.
I had driven the old HURST shifter for so long, I have gotten used to it, but I must say the new shifter is a lot easier to get into 1st and reverse, though I agree that most of the shifting problems are a characteristic of the transmission and not the shifter...
It looks taller because the stick is exposed and not covered by the boot, but the main reason I changed was because I liked the retro look of the rectangular stick..
Hurst billet shifter with stock boot...
