DIC Selectoer Button Malfunction
Old Jul 22, 2013 | 12:39 PM
lobooth's Avatar
lobooth
1st Gear
Default DIC Selectoer Button Malfunction
I am a newby, so be gentle.
I have a '98 C5 that I have put 205,000 miles on. I recently began having problems with the DIC flipping randomly through the sensor displays on it's own. I had the battery checked and while it is old, it seems to be holding charge OK. What voltage must be maintained in order for the DIC to function properly?
Also, none of the selector buttown are functioning any longer. If there is a malfunction in the button cluster, is there a way to test for it before removing the dash to get at the cluster for replacement?
Thanks for your help.
Old Jul 22, 2013 | 12:59 PM
dadaroo's Avatar
dadaroo
Here is a link to someone who had the exact same thing happen.
http://forums.corvetteforum.com/c5-t...t-working.html
It never says what he finally did but you can email/PM him. Does not seem like a battery issue in my opinion. Most likely it is the actual switch itself. I will help further as needed.
Old Jul 22, 2013 | 01:14 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Are there any codes that come up?
edit - Are you even able to retrieve the codes?
Old Jul 22, 2013 | 01:18 PM
Gl!tch's Avatar
Gl!tch
I have a 99 coupe with 113k on it and it does the same thing. Seems to happen with sudden cool-hot temp changes and other times when I hit a bump. Kind of sporadic, but yeah..it goes through the entire menu, and I can most of the time get it to stop by pressing one of the other buttons. Other times..just have to let it run its course. No codes.
To DIC Selectoer Button Malfunction
