convertible top fabric question
Old Jul 22, 2013 | 10:09 PM
wild oats's Avatar
wild oats
Default convertible top fabric question
My '02, Black,13k miles / has been well babied, /I have lighter lines on the fabric after returning it up, ( where the folds were, the two corners too) ..I always kept it clean(lint roller) and it's never been outside much..I'm quite reluctant to treat it.
Is this normal..?.Thanks all.
Old Jul 22, 2013 | 11:29 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
The crease or shiney marks are the result of the top rubbing up against itself when stowed/driving.
A good idea is to place a thin foam mattress pad between the sections when the stop is stowed.
As to the existing marks, try using a brush designed for fabric convertible tops that helps raise and clean the fabric. A good cleaner like Ragg Topp also helps.
Old Jul 22, 2013 | 11:34 PM
jcgunn's Avatar
jcgunn
I have treated my 03 from day one in Sept 2002 with 303 cleaner and 303 water repeller about twice a year. The top is like new and looks like it will last many moons. (mine is always garaged and the top is usually up (I know...) I put the top down for cruises thru the mountains, beach (not here in ID) etc. 89K miles.
Old Jul 23, 2013 | 12:01 AM
wild oats's Avatar
wild oats
Ah, common sense. ye ole thin mattress pad it will be .perhaps some 303 down the road. thanks !
Old Jul 23, 2013 | 05:34 AM
Ronnie wilkins's Avatar
Ronnie wilkins
Will the 303 also restore the black look on black tops? My top is in great shape but it is starting to get a little faded. Not to noticeable by it's self but beside a newer ont you can see the difference. Perhaps dying them would work?
Old Jul 23, 2013 | 10:51 PM
rws.1's Avatar
rws.1
I use a bath sheet
thinner than a mattress does the same trick and in a pinch can be used for other purposes ....
To convertible top fabric question
