Oil on plugs?
Old Jul 28, 2013 | 01:41 PM
BmoreRnsDeep's Avatar
BmoreRnsDeep
Default Oil on plugs?
So I changed my spark plugs yesterday and noticed some residue on the pulled plugs. Looks like oil but smells like unburned fuel. Cant tell but the plugs don't look fouled to me. The response is much improved after the change, but my bumpy idle remains, it doesn't do it all the time and only in neutral, and does loop like its missing.
No codes that I know of.
Old Jul 28, 2013 | 01:47 PM
calvins's Avatar
calvins
Oldtimer
Don't know about the plugs, any codes being thrown? As for the pictures, there are threads for "how to" - use the advanced search feature of the forums. There are plenty of threads with the steps.
Old Jul 28, 2013 | 04:20 PM
Sonny71's Avatar
Sonny71
Oldtimer
Just looking at the plugs, the gap seems pretty wide, did you check them after you pulled them?......my 2 cents worth
Old Jul 28, 2013 | 08:33 PM
OneCylinder's Avatar
OneCylinder
St. Jude Donor '13
Those plugs don't look fouled by oil to me. If they smell like burned fuel, that's what they do burn fuel.
Old Jul 29, 2013 | 08:40 AM
BmoreRnsDeep
No i know they dont look fouled and I know what spark plugs do. On the threads you can see some shinny fluid. Is that oil or unburned fuel?
Old Jul 29, 2013 | 12:07 PM
dadaroo's Avatar
dadaroo
The plug tip and electrode look good. The threads don't look like a concern to me. The threads are not there to seal against the engine internals, they just allow you to torque the plug, the sealing area is near the end of the threads away from the electrode. Expect for them to look like this after long usage.
Old Jul 29, 2013 | 12:55 PM
OneCylinder
St. Jude Donor '13
Oil fouled plugs that I've seen do have a shiny black residue. The only time that I've seen fuel on a plug was a carbureted motor unable to start, for example flooded. If the engine fires up, it'll be hard to see unburned fuel even if the cylinder misfires because that fuel is going to dissipate or evaporate.
IMO
Old Jul 29, 2013 | 05:47 PM
Paul 75 L82's Avatar
Paul 75 L82
Plugs look normal, if your getting oil in the cylinder they would be black.
Old Jul 29, 2013 | 05:55 PM
El original's Avatar
El original
They look great, but as mentioned by another reply, the gap looks way too large.
To Oil on plugs?
