TPMS Help
Old Jul 29, 2013 | 11:04 PM
Marine One's Avatar
Marine One
Default TPMS Help
Hi Everyone,
I'm getting ready to replace tires on my 2003 Corvette. The TPMS are original and I am having a couple of problems with them, so have decided this is a good time to replace. I've been through the posts here using the search feature and want to verify that the following will be the correct replacement for my car:
http://www.amazon.com/ACDelco-25773946-Pressure-Monitoring-System/dp/B000J9Y1T8/ref=sr_1_3?ie=UTF8&qid=1375153066&sr=8-3&keywords=tpms+corvette http://www.amazon.com/ACDelco-25773946-Pressure-Monitoring-System/dp/B000J9Y1T8/ref=sr_1_3?ie=UTF8&qid=1375153066&sr=8-3&keywords=tpms+corvette
Thanks in advance.
Old Jul 29, 2013 | 11:16 PM
Ho0osierdaddy's Avatar
Ho0osierdaddy
It has a check fit feature on that website and I did It for an 01 coupe and its a fit for them. Did you try that for yours
Old Jul 29, 2013 | 11:24 PM
Zr-1Mike00's Avatar
Zr-1Mike00
I can't speak for anything on Amazon... And I dont exactly trust their "Select your vehicle" feature however Gene with GM PartsHouse sells the whole lot. They may be a few extra bucks over the auction/amazon type sites however he is a supporting vendor. And great vendors such as him keep this site free to us!
Forum helps you find em, forum helps you buy em
I wouldn't go anywhere else if I were buying a new GM part.
Just my $.02
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 – sensor – $42.47 each
15234846 – nuts – $4.16 each
Total setup of 4 is $186.52
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
The Site:
http://www.gmpartshouse.com/index.php
Old Jul 29, 2013 | 11:52 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
That part number on Amazon is a good GM number and it should fit your car and is a great price.
Go for it.
Mr.Bill
Old Jul 30, 2013 | 08:45 AM
That is a good price on Amazon for a genuine GM sensor.
To TPMS Help
