cool c5 corvette features
Old Mar 10, 2015 | 11:41 PM
Beau168's Avatar
Beau168
I wish these had a trick to wind up all the windows by using the key fob! Would be so much easier when putting the top back up!
Old Mar 11, 2015 | 04:18 AM
703's Avatar
703
They do, While it's not a stock option you can buy a "window valet" that allows you to do this. They pop up for sale on the forum pretty often and are around 100.00
Old Mar 11, 2015 | 12:26 PM
Beau168's Avatar
Beau168
Thanks, Will defo check this out
Old Mar 11, 2015 | 02:29 PM
JEH03Vette's Avatar
JEH03Vette
● If you hate DRLs you can pull the e-brake ONE click and they go off.
This one has never worked for me.
Old Mar 11, 2015 | 04:58 PM
Choreo's Avatar
Choreo
Probably one of the most amazing features it how the C5 scans your wallet each time you enter the car and if it senses over $100, the DIC displays a repair code!
Old Mar 11, 2015 | 05:39 PM
73Corvette's Avatar
73Corvette
that's funny
Old Mar 11, 2015 | 06:56 PM
ssrallyred's Avatar
ssrallyred
Guess I have been lucky. The only "stock" part I have replaced that I had to was the reverse light switch on the side of the transmission. If it goes bad you have no reverse lights and its on the same circuit as the auto dimmer on the rearview mirror. All other expenses have been self inflicted 03Z with 51K.
Old Apr 4, 2016 | 05:56 PM
Vettewench's Avatar
Vettewench
Default Print out the hints
Originally Posted by Ole Blaster
too bad it won't print out...
If you want to print this. just copy and paste it to word and print it out!
Old Apr 4, 2016 | 09:33 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Old Apr 5, 2016 | 08:27 AM
ttiros's Avatar
ttiros
Originally Posted by Rico7142
That is good!!!!
Old Apr 5, 2016 | 02:13 PM
friou's Avatar
friou
Thanks for the chuckle, still smiling on that one! Best wishes!
Old Apr 5, 2016 | 02:16 PM
friou's Avatar
friou
Always useful and good reminders, thank you. Best wishes!
Old Apr 5, 2016 | 02:34 PM
  #33
BmoreRnsDeep's Avatar
BmoreRnsDeep
How do you set the shift light on the HUD? I never knew that, pretty cool.
Old Feb 28, 2017 | 01:14 PM
  #34
Corvette Forum Editor's Avatar
CorvetteForum Editor
Default How-To Tuesday
Seems like a great topic for today's How-To Spotlight...
https://www.corvetteforum.com/how-to...-the-c5-375436
Old Feb 28, 2017 | 06:35 PM
  #35
GRAND SPORT GUY's Avatar
GRAND SPORT GUY
CORVETTE FORUM EDITOR-
Thank You for bumping this post. Although it is an old one, I am coming over from the C3 section, and would not even know how to look for something so varied and esoteric as far as this collection of information.
My buyer just found me several pristine Silver/Gray C5's to peruse and choose from, I will be joining the C5 Clan shortly, and appreciate any and all information I can garnish here!
I will post photos upon delivery of whichever C5 I decide on.
Here is my C3 for reference! This was New Year's Day in Chicago, and this is the frozen (at that time) Monee Reservoir. I have been able to drive the Vette at least 4-5 days each month this winter, with rain showers washing the salt away frequently.
-Ray
Old Feb 28, 2017 | 06:55 PM
  #36
SunnyRainbowHeart's Avatar
SunnyRainbowHeart
Default WONDERFUL MOSTLY UNKNOWN FEATURES of the C5
THANK YOU SO MUCH, GMBAL4! I DIDN'T KNOW ANY OF THIS EXCEPT FOR THE SIDE VIEW MIRRORS!
Originally Posted by gmbal4
I hope that this is not a repost I ran across this by accident so I copy and paste the info ....pretty cool info btw I tries the key fob to unlock the doors and pop the trunk and it worked !! LOVE THIS VETTE !!
here is a small list of things you might not know about C5, did you know:
● That you can put your key in the driver’s door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
● That you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
● The little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
● All of the option codes are in the glove box.
● Tire inflation recommended pressures are on the driver’s door.
● The thing that looks like a little LED near the DIC buttons is a light sensor.
● The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun.
● The build sheet is in the front re-bar.
● If you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let youknowyou have old timers disease.
● You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running).
● Hold down the reset button while on one of the trip odometers and it changes that reading to the miles you’ve traveled since last starting the engine.
● Hold down the Active Handling button for 5 sec. to engage “Competitive Driving” on cars equipped with active handling (2000 and previous years must be stopped.)
● If you pull the seatbelts all the way out while you’re buckled in, they ratchet back in to hold you tighter into the seat. (then move the seat forward to make it extra snug -- Leafty)
● Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not flash. Your front turn signals will operate normally, however.
● The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
● There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment behind the carpet and on the side of the car. Not that it really works well.
● Also you can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
● If you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
● There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key. You should have a compartment on the drivers & passenger’s side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an ‘indent’ that holds the wheel lock key.
● If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on.
● If you have the passive entry feature: If you lock the keys in the car, wait a few minutes and then shake the car. That will unlock the car.
● HUD has a shift light for the manuals.
● You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
● You can eject the cd from the in-dash player without turning on any power. Don’t even need key in the ignition.
● The cruise will disengage if you purposely make sharp side to side turns while cruising at say 60-80 mph.
● When the engine is shut off, you can get the odometer reading by turning on the parking lights.
● You can program setting #3 (both memory buttons at once) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
Old Feb 28, 2017 | 08:39 PM
  #37
Ducati Guy's Avatar
Ducati Guy
very cool. Just printed it and will soon play around with some of the 'discoveries".
