Why does your opinion matter?
why don't we try and get some of the "experts" to lay out there credentials?
I am no expert but I have a 4 year engineering degree, 30 years of experience working with machinery that is mechanical in nature. I am an ASE Certified Master Mechanic. I am also certified as a Machinist for Submarine Repair.
I would be interested to see what some of the experts who argue with Mr Bill and ET are toting for credentials?
any arm chair experts up to the challenge?
What I like to see in a technical discussion/argument is logic backed up by documentation. ET provided both in his answer to my question, and that carries more weight than his credentials.
(The wording of his response was somewhat condescending, but I'll cut him some slack based on the amount of abuse he'd already taken at that point.)
On a side note, I am by no means an expert. I do try & give my opinion/advice to folks when I have specific knowledge on a subject. Mostly because again I have gone thru a certain issue & found a solution that has worked. I also always give this advice to try & HELP. I do think that while credentials, education are important, that also needs to be accompanied by experience (after all life does not always go "by the book"). Like all forums, this place has folks that truly try & help & others that just criticize. I do feel that CF is a VALUABLE place that has helped me plenty over the years. I also understand that you are never too young or old to learn something. I for one, learned something out of that oil post. I will now pre-fill the filter. So, to me that thread was valuable.
ET & Mr. Bill have both helped me in the past & for that I an ever thankful.
They give a lot to this forum and I don't get why some people cannot at least be polite or have something to back their statements up when they decide to disagree with them.
It's fine to disagree with anyone so long as you have a good reason to and can back it up with facts.
But then again opinions are just like azzholes - everyone has them - some just smell worse than others.
I think we learn to recognize those opinions that have merit over those that are just thoughtful opinion . . or blowing smoke.
Just my .02 - -
I like to think I'm one of those, even though I may not post as often as some others that are respected. Mr's Bill, ET, along with the guy from England (sorry I'm old and forget names) are certainly among the respected.
The problem with your question is you are assuming someone who is not an engineer has zero knowledge. Also some of what people claim as facts has no factual basis.
Like the oil change argument of recent.
I researched it.
No where does it say that you MUST insert oil in a filter. I've read it's suggested, I've read a lot of people do it, but nowhere have I read it's a must.
Our FSM doesn't mention it either.
So just because some here says something, does not necessarily make it fact.
What I do know is engineers THINK they're smarter than everyone else. There lies the problem.
As discussed before a lot of the topics that surface here have been discussed in quite some detail at one time or another... And being on this forum let's just say a little too much, I absorb a ton of information about a wide variety of subject matter. I might not know an answer for sure but if I don't, I know where to go and find it and be of some help and share it with others. Crediting my sources as I go.
If it is a subject matter that I am completely unfamiliar with I simply buzz to the next thread, my input would be of no value. Maybe a "good luck with the issue you are having" but that's it. I'm not trying to give misinformation or pretend to know something I don't. Money can be wasted and time can be lost...
Just my .02 - -
but the 20+ years of busted knuckles is in and of itself street credentials
I am more looking for say an individual who works in a non technical field that has owned a few Vettes but paid the stealer-ship to do work. doesn't even own a set of tools who then apply common sense and argue with experts
I researched it.
I found this on the Bergmen Engineering website. This is a right up on a new oil filter adapter they make for Kawasaki Bikes.
Note the #3 feature that makes this a better design.
A few of the many features:
1.Simple, rugged, very strong design, precision machined from the best and strongest materials available and all parts are 100% quality control inspected. This is a highly engineered design.
2.Designed to be compatible with more than 68 modern, inexpensive automotive and motorcycle specific spin-on oil filter models with superior filtering performance available from literally dozens of oil filter manufacturers and resellers.
3.Unique to this Adaptor, it allows the pre-filling of the oil filter with the motor oil of choice prior to installation. This greatly reduces the oil pressure build-up lag inherent in the stock (or standard) oil filter apparatus at startup immediately following an oil/filter change.
This thread has the potential to become epic
