Anyone using a Stubby antenna?
Aug 5, 2013 | 12:49 AM
Found a stubby antenna for C5's online...Looked like a good idea, is anyone using one
Aug 5, 2013 | 12:58 AM
St. Jude Donor '13-'14-'15
I use one, I like the look better, and to be honest I've had no issues with performance (radio) there are tons of styles to choose from.
Aug 5, 2013 | 01:15 AM
Works awesome. No loss of performance, but I mainly have an iPod plugged in.
Aug 5, 2013 | 01:36 AM
I'm using the one from cravenspeed its awesome
Aug 5, 2013 | 01:47 AM
Quote:
Originally Posted by
OKZ06
I got the same one a couple of weeks ago and I haven't noticed any difference in signal strength and it looks WAY better on the car.
Aug 5, 2013 | 10:13 AM
St. Jude Donor '09-'10, '14
I use the one that actually looks like the stock antenna but only 10 inches tall.
Aug 5, 2013 | 10:38 AM
Oldtimer
I guess I'm lucky, my '99 doesn't have an antenna!
Aug 5, 2013 | 11:30 AM
St. Jude Donor '13
Silly question, but I don't know if all the C5s came with the electric antenna or not. If so, I am assuming this replaces that whole setup? Mine still works fine, but I don't necessarily like the looks of it when it is up.
Aug 5, 2013 | 11:34 AM
Glenn Jenne
Verts have a power antenna, Coupes have antennas embedded in the windshield, Z06s have the fixed mast antennas,
Aug 5, 2013 | 12:08 PM
St. Jude Donor '13
So...can you use a stubby to replace the power antenna? I like the looks of the stubby much more.
Aug 5, 2013 | 01:17 PM
Can't think of any reason why you couldn't. Just get the Z06 fixed assembly and replace your power unit. You may be able to find someone to trade.
Aug 5, 2013 | 01:53 PM
Glenn Jenne
I have known people who did replace their power ant with a fixed antenna.
I replaced one on a Honda Accord one time myself.
Aug 5, 2013 | 02:01 PM
St. Jude Donor '13
Thanks Mike and Ron, now I have some new ideas. -Glenn
Aug 5, 2013 | 02:41 PM
Glenn Jenne
I added a switch to my power antenna. It's only up when I flip the switch, which I rarely do. Reception is great when it's down unless I'm really out in the boonies.
Aug 5, 2013 | 02:45 PM
skydiven4fun
The one in the picture is from craven speed...what other styles have you seen?
Aug 5, 2013 | 02:56 PM
Those work on a Z06 or FRC, but if you want one on a convertible, you'll have to replace the whole antenna ***'y. The ones pictured screw onto a stud that is not present on a convertible.
Aug 5, 2013 | 04:15 PM
The first mod I did to my Vert when I bought it was replace the Antenna. The stock power one is a real eyesore.
The stubbies are a good option, if you search there are plenty of threads detailing how to replace the power antenna with a stubby.
The power antenna also has decent reception when its down. You can simply unplug it, and it should be acceptable unless you're out away from the city.
I replaced mine with a hidden amplified antenna that's mounted inside the rear quarter panel. The reception is on par with stock.
http://forums.corvetteforum.com/c5-g...a-install.html
Aug 5, 2013 | 04:32 PM
Ron C!
1999-2000 FRC ( hardtop ) have fixed ant. also...
Aug 5, 2013 | 05:19 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
RetiredSFC 97
Shorty antenna FTW!
Aug 5, 2013 | 05:59 PM
If you find someone that wants the power antenae, they'll need to reprogram their BCM if they install it on a FRC/Z06.
