Heads and Cams recommendation
Old Aug 5, 2013 | 12:32 PM
typeav's Avatar
typeav
Default Heads and Cams recommendation
I'm looking for recommendation to replace the stock heads and cam for my 2003 C5, I have done the headers, exhaust and intake already. So my next purchase will be the heads with cams, manifold 107 or 92mm ? and the body throttle. I have to spend on the heads and cams between $2k - $3k
Any other part that I need with the upgrade that I'm missing ?
Thanks!
Old Aug 5, 2013 | 01:05 PM
Vette Moto's Avatar
Vette Moto
what's your power goal? that will really help narrow your parts search down. I hear good things about AFR 205 and 225 heads and Trickflow 215, but selection of heads will depend on your complete setup and power goal.
My LS6 made 473 to the wheel on Trickflow 215 heads, Fast 92, LS2 TB, and custom cam 228/232.
Old Aug 5, 2013 | 01:11 PM
typeav's Avatar
typeav
I do not have a hp goal, just to make it roar like a mad beast.
I have my eyes on this one, so I do not need to upgrade anything else like the injectors ? Thanks!
http://www.westcoastcorvette.com/p-4...1-z06-ls6.aspx
Old Aug 5, 2013 | 01:34 PM
whitesmokels1's Avatar
whitesmokels1
2-3k is a lean budget even if you're doing the work yourself.
I feel like I've been doing this a while and it's not worth it to skimp on good parts.
Here's a list of recommendations to research.
dual springs/retainers/clips
hardened push rods
timing chain (ls2 or better)
lifters (ls7)
oil pump (high flow or ported ls6)
comp rocker trunion upgrade or aftermarket rockers
gaskets
and tune ($400+)
Old Aug 5, 2013 | 01:48 PM
typeav's Avatar
typeav
basically I always try to get the best stuff but that list of parts is to deep, I just want to have the mechanic remove the stock heads, mount the new ones and good to go. I'm not looking to go over 500 hp. Reliability on the engine is very important to me, I do not want to have a dead engine
Old Aug 5, 2013 | 02:29 PM
cammedvette's Avatar
cammedvette
Doesn't sound like you will be able to go the Trickflow or the AFR route with that budget? I faced the same ordeal with my 99 Coupe. I ended up with new LS6 Heads as well as LS6 intake and a Comp cams 230/232... Altready had the CAI and long tube headers, high flow cats as well as Corsa catback. I have about 18K on this setup and it is really nice and reliable with a mean lope at idle and respectable power. Had to upgrade the springs in the heads but purchased all and had it installed in the $1800 to $2000 range. Also had a nice street tune put on it and I have been ballparked with my setup at around 485 at the crank and 415 RWHP or so... Really makes the car fun to drive and sounds like a badass!!! I don't often run into anything on the street that will walk away from it (i'm sure they are out there, I just don't run into them!!) ... really fun!!
Old Aug 5, 2013 | 02:37 PM
hamhead's Avatar
hamhead
$2-3k is lean. $3k is probably closer to doable. And that is if you do it yourself
Once you factor in LS7 lifters you probably should upgrade ($150), new timing chain/oil pump ($200), injectors ($250), all your gaskets/bolts/fluids/belts($400), and a tune ($500), you've probably only left yourself only $800-1500 for your cam/heads package.
I don't know if I'd do all that work to go with a cheaper heads casting. You might only be able to afford stock LS6 castings on the low side of that budget.
Old Aug 5, 2013 | 02:41 PM
typeav's Avatar
typeav
can I just upgrade the cams ? will that work out or not
Old Aug 5, 2013 | 02:45 PM
hamhead's Avatar
hamhead
*Cam, we only have one
Sure you can, but a lot of the labor to swap heads is done on a camshaft install. Most people do it at once.
Old Aug 5, 2013 | 03:02 PM
baxsom's Avatar
baxsom
TSP CNCd 5.3L heads shaved .030, TSP 228R cam, FAST 78 intake, 440rwhp.
Old Aug 5, 2013 | 05:03 PM
typeav's Avatar
typeav
Ok after some research I have found that I can do a LS6 head swap with the results that I want, I'm planning to purchase the LS6 heads. Can I use this camshaft from Lingenfelter with the stock LS6 heads ?
GT12
227/235 duration @ .050 lift - .614/.621 lift with 1.7 rocker 115 CL
Old Aug 5, 2013 | 09:57 PM
Biomech011's Avatar
Biomech011
hardened push rods
lifters (ls7)
gaskets
and tune ($400+)
Agreed.
I am getting ready to do a Heads/cam /Intake/swap now. (From Texas Speed & Performance Using the MS4.)
At least, you may want to swap the Lifters, Pushrods, timing Chain & Gaskets. (Which all has wear from the original set up)
I went all out. Got the whole top end pretty much new.
Not cheap. I'm telling you if you want to do it right, Its gonna Snowball your budget.
Old Aug 5, 2013 | 10:20 PM
typeav's Avatar
typeav
I did the research, I'm planning to get the LS6 heads, Lingenfelter GT12 cam and Lingenfelter LSX Double Valve Spring Titanium Retainer & Seals Kit.
Im good to go now ?
To Heads and Cams recommendation
