Fuel level sensor issues
Old Aug 5, 2013 | 02:57 PM
ZeroGravity's Avatar
ZeroGravity
Default Fuel level sensor issues
Hello again!
I know that this trouble already have been discuss but cannot find solution.
On Friday I drive with my wife to the party. Suddenly car was stoped. Tank was empty. But indication of the scale was halfway. Taxi, nearest gas station, plastic bottle, screaming of tanker man cause pour a plastic bottle of gasoline forbidden. But this is Russia-a-a-a-a!!!111
And I return to my car with a plastic bottle full of gas.
After this incident, I decided to closely observe the scale. Full tank in fact, it may appear full or nearly full at scale. Half in fact -
without-quarter to full at scale. Empty or near empty in fact = half or less at scale. Sometimes (seldom) scrolling text show me "refuel".
In my humble experience float is broken. I saw part catalog and as far as I understand float is a part of fuel pump.
The price tag is not happy (about 1000$ with shipping). Maybe there is more cheaply solution?
Thank you.
Old Aug 5, 2013 | 03:09 PM
Phanni's Avatar
Phanni
Yes the sensors are part of the fuel pump located in the gas tanks (there are two (2) in a C-5 since it has two gas tanks.).
Here in the US we have a product called Techron. It a a cleaner that can be added to the gas tank when adding fuel. It works sometimes by cleaning the electrical contacts that registers the fuel level. (shows the amount of fuel left in tank) The product is manufactured by Exxon/Texaco here in the US. It costs about $10.00 US dollars here .
Another hint is to set your trip odometer when you fill your tank and keep track of the miles/kilos you put on the tank of gas. That too should keep you from running out of petrol.
Old Aug 5, 2013 | 03:20 PM
calvins's Avatar
calvins
Oldtimer
One thing you can do as well as using the Techron (if you can get it) is to run the best petrol available to you. 93 octane would be preferable if it is available to you.
Old Aug 5, 2013 | 03:22 PM
ZeroGravity
Thanks.
I found something at Russia. Techron Concentrate Plus 14$ is it this?
I heard something that American and European octane numbers are different. We have got 92 or 93 (regular) chipest. 95 (super) and 98 (super plus). And yours 87 octane is European 92
There is a myth hear in Russia that all American cars must be used with regular gas only.
And the second argument for regular gasoline is there isn't clean gas higher than 92 in Russia. All high-octane gasoline is with additives.
Old Aug 5, 2013 | 03:31 PM
andrec10's Avatar
andrec10
Originally Posted by ZeroGravity
Thanks.
Thats it! Run that for a few tankfuls and you should be good to go!
Old Aug 5, 2013 | 03:54 PM
Phanni's Avatar
Phanni
The additives in your 'premium' gas/petrol are probably some kind of 'detergent' which might help to clean the sensors on the fuel pump also.
Old Aug 5, 2013 | 04:12 PM
calvins's Avatar
calvins
Oldtimer
Good luck with the Techron, hopefully that will clear up your gauge issue.
As for the octane, the highest available in the area that I live is 93. The C5 manual recommends using 91 or higher for best performance. I don't know enough about the affects that a higher octane fuel would have on the LS1 motor so I'll leave that answer to others. I'm sure others will share their views.
Good luck to you.
Old Aug 5, 2013 | 04:19 PM
VETJAZZ's Avatar
VETJAZZ
Techron has solved this problem for many people. There's also a larger bottle that treats up to 20 gallons. Probably a better choice for the vette.
Hope you can find it in Russia. Welcome to the forum!
Old Aug 5, 2013 | 04:20 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
You may have to treat your tank more than once with the techron for it to clear up, if that is fact your problem.
Old Aug 6, 2013 | 05:29 AM
ZeroGravity
I ordered four bottles of this liquid. Hope it would be enough. After tomorrow it will comes from stock.
Old Aug 6, 2013 | 10:03 AM
Thanks.
That would be the stuff. Try running a bottle through each of your next couple of tanks of gas and see if it will clear the sulfur deposits off the sending unit.
Old Aug 6, 2013 | 10:07 AM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
Здравствуйте и добро пожаловать на форум Corvette. Я медленно изучения русского языка. Моя подруга 4 года из Молдовы
Adding Techron is the first step with fuel problems. After you have ran it through 2 tanks of gas and if the problem still is there the forum will be a great help.
By the way go to the link below and say hello...
http://forums.corvetteforum.com/c5-g...-theforum.html
Old Aug 6, 2013 | 11:37 AM
dadaroo's Avatar
dadaroo
You know the Russians invented Techron.
Just kidding, an old joke. Let us know if that does not solve your problem. Sometimes the right tank does not transfer fuel to the left tank. If you still have issues we need to get some more information from you to determine what is going on.
PS: I once read a book on anti gravity. I just couldn't put it down.
Old Aug 6, 2013 | 03:01 PM
ZeroGravity
Damned seller called me and tell that Techron is over and if I want it there will be a month delay (shipping from USA).
Unfortunate but I found only one official dealer of Chevron and Texaco in Russia and it is wholesaler only.
Well-known American oil brand in Russia is only Mobil.
After work I visited a part-store. There were lots of similar liquids. "Injector cleaner", "Fuel system cleaner". I bought one German and one Russian bottle. Try to use them for first time and tommorow continue searching Techron in stock. In case of failure have to wait Techron from USA.
Приятно увидеть русскую речь на форуме о Корвете! Передавай привет подруге из бывшего СССР. Молдованки часто бывают очень красивыми. Южанки все-таки.
OK! I'll do that.
I understand that here is a joke. But i can't understeand it's meaning. Could you tell?
Old Aug 6, 2013 | 04:33 PM
Phanni's Avatar
Phanni
Many years ago when the USSR existed, the standing joke was every time a new invention became very popular Kruishev (bad spelling) often claimed the USSR invented it first.
It became a joke every time something popular was invented.
"we invented it first"
I hope that makes sense.
Old Aug 6, 2013 | 04:47 PM
Mickeyrx70's Avatar
Mickeyrx70
I spent a week in Moscow in 1992. Beautiful city. Welcome to the forum!
Old Aug 6, 2013 | 04:56 PM
LoneStarFRC's Avatar
LoneStarFRC
It was a BIG part of the cold-war propaganda efforts, the idea supposedly being that the People's Republic is the perfect system of government in the world and that all good ideas/inventions/engineering, etc. came from USSR minds FIRST.
Btw, it's "Khrushchev".
To Fuel level sensor issues
Old Aug 6, 2013 | 11:28 PM
Choreo's Avatar
Choreo
If you cannot find Techron, you might try Gumout - some people have had success with it...
I have personally used BG BK-44 on occasion and it worked when the Techron would stop working. It is pricy (about $25 USD per can/treatment), but it is a great product. I use it about twice a year and Techron in between.
Old Aug 7, 2013 | 12:20 AM
ZeroGravity
Understand. First time I went to school at 1992. One year without USSR. Boris Yeltsyn
But still there were many Soviet textbooks.
Math task: Communist Party of the Soviet Union was founded in 1912 year. How old it would be in 2013?
Reading:some texts about PArty, or young Lenin, or a stste farm.
Propaganda. And that time every grownup man think that all inventions in the WOrld are Soviet )))
But propagation is in a lot of countries. Propaganda is not bad at all. Majority German man sure that live in the best country. Majority French or Spanish or even Polish and Serbian people sure that live in best country.
The main thing is not to do it absurd like in USSR.
Now Moscow is much more beautiful. Lots of new buildings and bright lights. Would be glad to see you back here somehow
Old Aug 7, 2013 | 12:25 AM
strand rider's Avatar
strand rider
The suggested additive is in all the top tear gas available here, so it's probably over in your gas also, multinational cars and gas. Just always get the highest grade from a good company.
I don't know of the main Chemical in Techron, it has been posted here, and posted that most additives use the same stuff. It was developed at the request of Porsche who was having fouling problems with a new engine and getting complaints. Turned out to be a universal good additive so in the gas classification of "top tier " in the states, all run it.
Ask around, since modern Porsche engines have to have the stuff, a German garage might be helpful. Probably the German additive you have bought will have the same effect as Techron .
I don't get to wear my fur hat in California much, but I still have the good memories of the people I met. Hopefully your gas price is not a fun killer.
I had my mind blown long ago when a black Monte Carlo started doing burn outs up and down the Odessa main drag, (I can not spell the famous street) in the middle of severe communist Russia. Perhaps your grandfather?
