Car Cover
I can't contradict the caution about paint damage, But with my paint and standards of maintenance , I have seen no damage from any of my car covers over many years. A softer paint or more demanding needs might tell another story. I also brush off the road dust before I place the cover.
My used car came with a non woven white Tyvek type cover designed for compactness, in that it is designed to roll into a small container. It's thin and white, but is only a loose fit, as is common with less elaborate construction.
I combine the two, on top, the bright white of the thin cover reflects the sun and keeps the primary cover clean. I don't know if you have ever washed a car cover, but they are bulky and non woven in the Dupont types of material, and don't look the same after washing. Still the same function, but the material is now fluffier, which I didn't think the best result for long term use. The top cover protecting the bottom cover also helped with a few cat attacks and of course, birds. The non woven white outside cover now has a bunch of claw damage, but no completely torn areas, it just looks very shabby, kind of like a willow tree trunk. But my undercover is without any damage.
I like the two cover concept, I remove and use them together as one cover, so no extra work to deploy, and it keeps the good cover clean. The non fitted cover will blow off with a good wind unless I take the loop designed to wind the white cover into its' case and circle the tailpipes with it.
The white cover is not priced well, if it is still available. I like the light color, because I often park in the sun. If I were covering my car today, I would definitely get another well fitting cover, like the California car cover. The outside cover would be one of the generic covers that people are selling cheaply at the bigger car meets . It's a material that looks like the ones the fitted covers are made out of, but sells for much cheaper and the covers are approximate fits for the car, pretty much what I have now except grey car cover material on the cheaper outer cover.
I hope this helps. And that the new purchase is good to you.
This Introtech cover works very well.
