need a tutorial
Old Aug 14, 2013 | 04:29 PM
jpranchranger's Avatar
jpranchranger
Default need a tutorial
I just installed a set of halo taillights. I was already using a sequencial signal harness that worked great on the stock lights. Now the sequencial does not work at all. I took it out and reconnected the lights but now I am getting a hyper flash on my left side lights only. I would like to use the seqencial harness with these lights, and I dont understand why my left lights are the only ones that hyper flash. Can any of you tell me what I should do about these issues? Really appreciate the information if you can explain what is going on and how to fix it.
Old Aug 16, 2013 | 12:01 AM
Try posing your question to either JW Motoring or theradioflyer. Both are very knowledgeable on the lighting systems.
