[Z06] lowering...confused how it works
Old Aug 18, 2013 | 10:38 PM
93civEJ1's Avatar
93civEJ1
Default lowering...confused how it works
can someone explain to me how lowering our cars using stock stuff works? I come from cars that use coil springs and struts.
I see people talking about removing the bolts on the front to lower..and then ive seen some people mention tightening of the bolts to lower? how is this possible? seems like you would either losen or tighten to do one or the other.... how is it ? can someone explain exactly how this works....
Old Aug 18, 2013 | 10:45 PM
spdislife's Avatar
spdislife
There are numerous threads on this topic. Use the search feature and you'll have more han enouh info
Old Aug 18, 2013 | 11:00 PM
93civEJ1's Avatar
93civEJ1
i have searched and searched...but still dont exactly understand until I get under my own car. Does the bolt just act as a peg to press against the leaf spring..
Old Aug 18, 2013 | 11:17 PM
bumble-z's Avatar
bumble-z
93civEJ1, Welcome to the forum.
Here is a "How To", in regards to raising the ride height with the stock front & rear adjusters on a C5 Corvette.
In these instructions, you would just turn the bolts in the opposite direction (front & rear) to lower.
RAISING
http://forums.corvetteforum.com/c5-g...sing-a-c5.html
Old Aug 19, 2013 | 12:34 AM
Supercharged111's Avatar
Supercharged111
The front leaf pushes the a arms down and the rear leaf pulls them down. Reducing preload lowers the car.
Old Aug 19, 2013 | 09:02 AM
93civEJ1's Avatar
93civEJ1
RAISING
Boom...this is what I was looking for. Looks like the rear works opposite of how the front does. Now I understand how removing the front bolt would work compared to the rear etc.
Old Aug 19, 2013 | 10:58 AM
envyz06's Avatar
envyz06
good info in that post
Old Aug 21, 2013 | 10:25 AM
1965corvettecop's Avatar
1965corvettecop
I tried to get mine up some-- as the front air dam drags over a pebble it is so low. I couldn't get it up much? when I tighten the bolt up front it isn't smooth pursuit. It kind of bounces back to where it was. I understand rear, but front I am having trouble. I have 2001 z06
Old Aug 21, 2013 | 12:48 PM
corvette_racer_john's Avatar
corvette_racer_john
good info. Thanks.
Old Aug 21, 2013 | 02:50 PM
rjwz28's Avatar
rjwz28
Having trouble getting it up, are we? I believe there is a small blue pill designed for that exact problem...
Sorry, I couldn't resist
Old Aug 21, 2013 | 04:50 PM
1965corvettecop
Ha! Guess I set myself up for that one..
Old Aug 21, 2013 | 04:53 PM
rjwz28's Avatar
rjwz28
Old Aug 21, 2013 | 06:36 PM
95wht6spd's Avatar
95wht6spd
Have the weight of the car on the suspension when raising front and back?
Old Aug 21, 2013 | 09:23 PM
1965corvettecop
No.. I had it on jack stands after jacking up with puck. I tried both putting pressure on suspension and just hang. I am going to try again, as I need it to come up some. If I have a passenger, it just scrapes the air dam something awful...
To lowering...confused how it works
