I need ur Opinion!!!
Old Aug 20, 2013 | 09:06 AM
1stZ06vette's Avatar
1stZ06vette
Default I need ur Opinion!!!
So my front signal lights are not in very good shape and was wondering what others are up grading to? There are a lot out there but I don't want the Euro Ricer look. So did know if u guyz could post pics or web sites on good deals for the lights.. If it helps my Vette is Red. Thanks
Old Aug 20, 2013 | 09:36 AM
NHolds's Avatar
NHolds
I got a set off Ebay for $60. They look nice to me, and were much cheaper than stock.
Old Aug 20, 2013 | 10:23 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Regardless of the replacement consider that the stock bulbs will melt the housing. I replacement both of my housing last year and inserted new stock bulbs and not the housing is melted. Time for LEDs.
rr
Old Aug 20, 2013 | 10:43 AM
Must_Have_Z's Avatar
Must_Have_Z
Clear corners from JW Motoring! Love them! White LED fronts, amber LED sides.
Old Aug 20, 2013 | 11:55 AM
PNW Vett's Avatar
PNW Vett
St. Jude Donor '13
I also went with the Ebay clear corners (great quality for $60), switchback LEDs DRL/turn signal and LED marker lights from JW Motoring. Very happy with the upgrade.
Old Aug 20, 2013 | 12:12 PM
1stZ06vette
Them look good!!! But would they look as good n a red vette? I guess that's one of my biggest conserns
Old Aug 20, 2013 | 12:28 PM
1stZ06vette
How much do the switchback LEDs DRL/turn signal and LED marker lights run?
Old Aug 20, 2013 | 12:55 PM
racebum's Avatar
racebum
direct oem looking replacements are something like $60 a set on amazon. depo is who makes them. they also have clears and other styles but there is such a thing as a direct oem lens for the same money as the clears
Old Aug 20, 2013 | 01:02 PM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
It's a slippery slope making the upgrade to Clear corners...
1. Start with Clear Corner housings from Ebay or a Supporting Forum Vendor.
2. Buy LED Switchback bulbs to replace the stock bulbs to prevent melting of housing AND the Hyberflash Harness
3. Swap to LED 194 bulbs for the corner light in white or amber to keep legal if required in your state
At this point you realize how nice your new DRLs look...and more importantly how crappy your OEM fogs and lo/hi beams look, so you end up buying even more stuff.
4. HID ballasts/bulbs for the fog lights
5. Either HID ballasts/bulbs for the Lo/Hi beams OR full on projector headlamps (many options here depending on how much you want to spend).
All said and done your in for at least $300 in front end lighting and more if you go with projector headlamps.
Or I can sell you my factory DRL housings that still look pretty good for $50?
Old Aug 21, 2013 | 08:45 AM
1stZ06vette
Yea idk y but my vette didn't come with fog lights so I guess I can skip that stage.... But thanks you uve been a big help
Old Aug 21, 2013 | 08:53 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Here's another example of aftermarket corner lenses with LED switchback bulbs. Mine are black with clear/amber lens.
Old Aug 21, 2013 | 09:08 AM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
[IMG][/IMG]
I had the same issue as most have had, with the bulb melting the casing, directly over the bulb (see old casing in photo).
When I got new ones, I cut a small hole, exactly where the melting takes place. Conveniently, the hole in the black frame attachment part, exactly is in the same place as where the bulb melts the casing. So, I JB Welded a 'new roof' of sorts over that location. And it fit neatly through the whole in the black part which attaches to the car.
In effect, raising the top of the casing another inch or more, away from the heat of the bulb. I did two coats, and then applied a little high heat caulk, to ensure a waterproof seal. Did this over a year ago, driven in rain many times (this is Illinois weather), and no problems; so far.
If I were you, and getting new bulb casings, I'd do this. Unless you go to the other type of bulbs which do not generate the same heat apparently.
Good luck.
Old Aug 21, 2013 | 09:15 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
To be honest there isn't much in turn sigs for the C5, You can get them with different mods done to them.
I have the clear corners and really like them, They seemed to really update the frone a lot.
Mr.Bill
Old Aug 21, 2013 | 10:20 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Clear corner's and LED's.
Old Aug 21, 2013 | 10:29 AM
envyz06's Avatar
envyz06
Mr.Bill
I can't seem to find clear corners with chrome like this, anyone have ideas? I can only seem to find black like this.
Old Aug 21, 2013 | 10:47 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Ebay corners, with LED bulbs, and LED strip mod from Radioflyer.
Old Aug 21, 2013 | 12:43 PM
corvette_racer_john's Avatar
corvette_racer_john
man that looks nice.
To I need ur Opinion!!!
