Generator light
Old Aug 23, 2013 | 04:44 PM
1978vett's Avatar
1978vett
Default Generator light
My 78 hadn't been started for a couple days, when I started it today the generator light came on. It was still on when I got to the hardware store.. when I came out and started it the light came on again,, About half way home it went off .. I started it again after I got home and it stayed off.. It hasn't did that before..Any ideas where to start checking ? Thanks
Old Aug 23, 2013 | 05:13 PM
StatmanRN's Avatar
StatmanRN
You might want to post this in the C3 section!
But since youre here...check your alternater output voltage. I had a 73, light would go on when alt volts were low.
Also check for slipping belt which will also do it
Old Aug 23, 2013 | 05:14 PM
Phanni's Avatar
Phanni
Start checking in the C-3 section.
Save that, get your battery/alternator/generator checked out at a parts store or auto repair place.
Old Aug 23, 2013 | 08:47 PM
that you will get more help in the C3 section, but you have an alternator, not a generator on the car.
Old Aug 23, 2013 | 10:43 PM
1978vett's Avatar
1978vett
I agree also and am sorry for posting in the wrong forum.. I have tried to delete my post but that is not a option,, Also I know that it has a alternator, but the light on the dash says generator..
Old Aug 24, 2013 | 06:38 AM
o2bnkc's Avatar
o2bnkc
Check your belt. For you other guys, so he's in the wrong section. Big deal!! A c5 alternator works the same as a c3 alternator. Gimmee a break. Just try to answer the guy's question.
Old Aug 24, 2013 | 09:07 AM
65GGvert's Avatar
65GGvert
Maybe you'd get more help if you posted in the anger management forum.
Old Aug 24, 2013 | 09:19 AM
Phanni's Avatar
Phanni
At least the OP understood our posts. Some folks enjoy a bit of fun poking, others don't.
Old Aug 24, 2013 | 07:16 PM
o2bnkc's Avatar
o2bnkc
Maybe you should post in the " I got no idea so I'll just rag on this guy forum."
Old Aug 24, 2013 | 08:03 PM
65GGvert's Avatar
65GGvert
Nope, you're the only guy I'm raggin on. I didn't speak to the OP. I know what his problem is, but I can't answer cause it's in the wrong forum.
Old Aug 25, 2013 | 09:11 AM
1978vett's Avatar
1978vett
Problem solved,once again,sorry for posting in your forum..
Old Aug 25, 2013 | 09:50 AM
Marine One's Avatar
Marine One
Why can't we all just get along?
Old Aug 25, 2013 | 09:53 AM
65GGvert's Avatar
65GGvert
You've got nothing to apologize for. The guys were just pointing out that the C3 forum was more likely to have the correct answers for your problem. Regardless of what you heard, a charge problem is quite different between C5's and C3's. It's good that you have your problem resolved though. Any time you post a problem, it's nice for others if you also post the fix so others using search for the same problem may be helped by your experience. Good luck with your car.
Old Aug 25, 2013 | 10:42 AM
1978vett's Avatar
1978vett
I tightened the belt and the light hasn't came back on.. Thanks for your help..
To Generator light
