turn signal wont work
Old Aug 25, 2013 | 11:36 AM
C5Wolfe's Avatar
C5Wolfe
Default turn signal wont work
My right front turn signal and flasher on right front wont blink. I replaced the bulb but there is no power to the bulb socket [tested it with a test light]. The rear signal on the right blinks but it is extremely fast. Any ideas appreciated...
Dave
Old Aug 25, 2013 | 11:44 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Try pushing in and out your 4 way flasher about 10 times real fast and see if that helps, They are tied to the 4 way. If it then works you need the flasher mod.
Old Aug 25, 2013 | 11:48 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
need to replace the socket most likely....you can get them pretty cheap at auto parts store..
the flasher fix is when none of them work
Old Aug 25, 2013 | 01:48 PM
zesstey1's Avatar
zesstey1
You can go through the brake duct and clean or replace socket. I've had to do this on all the
c5s I've had.
Old Aug 25, 2013 | 04:54 PM
C5Wolfe's Avatar
C5Wolfe
I got it working!!! The new bulb I replaced the old one with was bad also. I just cleaned the socket and put an old bulb out of my old "97' in and all is O.K.! Now for a beer to help heal my skinned up arthritic hand! I normally wouldn't drink at 4:55 but it is medicine so its O.K.
Thanks for the help guys!
Old Aug 26, 2013 | 07:36 AM
zesstey1's Avatar
zesstey1
Cool, if going through the brake duct I pray my hand with Wd 40 it helps alot.
To turn signal wont work
