No Brake Lights
Old Aug 25, 2013 | 03:02 PM
sprentice's Avatar
sprentice
2nd Gear
Default No Brake Lights
2002, C5 Corvette with no Brake Lights? Checked Bulbs, Fuses and replaced Multi-Function Switch, but still no Brake Lights?? What next??
Old Aug 25, 2013 | 07:26 PM
slvr bulit's Avatar
slvr bulit
Broken wire? Bad ground?
Old Aug 25, 2013 | 07:44 PM
repman's Avatar
repman
Most likely the hazard light switch on the dash common issue related to no brake lights
Old Aug 25, 2013 | 07:47 PM
65GGvert's Avatar
65GGvert
The third brake light doesn't go through the flasher.
Old Aug 25, 2013 | 07:54 PM
repman's Avatar
repman
That is true but he did not say if the center light was working if its the left and right out its most likely the flasher switch
Old Aug 25, 2013 | 08:38 PM
Phanni's Avatar
Phanni
Besides the multi function switch, there is at switch on the brake pedal.
A quick check is to use your cruise control and see if it disengages when you apply the brakes.
Old Aug 26, 2013 | 12:46 PM
tacman's Avatar
tacman
St. Jude Donor '13
any LED's? I had no brake lights due to sequential turn signals. Installed Hyper-flash harness.
No more problems.
To No Brake Lights
