[Z06] Check engine light
Old Aug 25, 2013 | 08:05 PM
ZO6*'s Avatar
ZO6*
Cruising
Default Check engine light
I have an 01 zo6 with long tube headers, and borla stingers. I have a p0420 code....anyone have this problem....car runs perfect
Old Aug 25, 2013 | 09:23 PM
ZeeOSix's Avatar
ZeeOSix
DTC P0420 or P0430 = Catalyst System Low Efficiency.
P0420 TWC System Low Efficiency Bank 1
Bank 1 is the driver's side.
Try the search function ... probably some threads on this DTC. Search for "P0430".
Old Aug 25, 2013 | 11:45 PM
ZO6*'s Avatar
ZO6*
Cruising
O2 sensors? Before or after cat? Cats?
Old Aug 26, 2013 | 03:30 PM
tlove32's Avatar
tlove32
Has the car been dyno tuned?
Old Aug 26, 2013 | 11:15 PM
ZO6*'s Avatar
ZO6*
Cruising
Nope. Got it a few weeks ago.
Old Aug 26, 2013 | 11:19 PM
jss812's Avatar
jss812
I'm not an expert but will give this a shot.
My understanding is that if you have high flow cats typical when installing headers, the rear O2 sensors don't heat up very quickly. Since the computer compares front to rear to determine cat performance, it will then throw the code because the two don't compare correctly (you can look up the reason, but I've seen two different explanations on what the computer is looking for. I don't think it really matters what as long as you understand that they are compared).
So the solution appears to be to delete rear O2 sensors which should include no mil for P0420/P0430.
If the rear O2 sensors have already been deleted, then sounds like setting P0420/P0430 to no mil was skipped.
Old Aug 26, 2013 | 11:24 PM
ZO6*'s Avatar
ZO6*
Cruising
Makes sense except that I bought it this way and the prior owner says he never had this problem?
Old Aug 26, 2013 | 11:34 PM
jss812's Avatar
jss812
Can't argue that one way or the other.
I have also heard that the car may click along just fine and then a high cross wind might cool the rear O2 sensor and throw the code. Or maybe you drive on a wet road and that cools the rear O2 sensors.
Of course, you might just have O2 sensors going bad.
Since installing headers, I haven't had rear O2 sensors so have no experience with the problem. But I would think you should be getting other codes if you have a bad sensor.
To Check engine light
