Seafoam Engine Treatment
Old Aug 28, 2013 | 09:19 AM
Big Ron's Avatar
Big Ron
Default Seafoam Engine Treatment
Went to O'Rielly Autoparts last night to buy some Techron like I do every month. The guy behind the counter was pushing Seafoam Engine Treatment over Techron. I bought the Techron but was wondering if anybody has used Seafoam Engine Treatment and what they thought of it?
Old Aug 28, 2013 | 10:26 AM
DooDooBear1999's Avatar
DooDooBear1999
Used it in an F-Body in the gas tank, brake booster, maybe the oil pan(?). Didn't hurt it and no codes. Big plumes of smoke coming out after I used it in the brake booster though, but it's normal.
Old Aug 28, 2013 | 10:29 AM
amlarson2001's Avatar
amlarson2001
When I have problems with my fuel gauge I tried sea foam first. It did nothing. One bottle of techron and she worked like a charm. You want to stick with the Techron.
Old Aug 28, 2013 | 11:29 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Mixed reviews about seafoam. You can youtube it as well to see some results. Some say it is snake oil, and some other like it.
Old Aug 28, 2013 | 12:38 PM
m6 c5's Avatar
m6 c5
Ive heard good things about it cleaning up carbon deposits in your cylinders but other than that I havent heard much else. I know when I used it in my camaro I had black water coming out of my exhaust so it must have done something.
Old Aug 28, 2013 | 06:09 PM
bighank's Avatar
bighank
Default Have used both Seafoam and Techron in the gas tank to address the gas gauge problem
Both seem to work. Just don't use both at the same time.
Old Aug 28, 2013 | 09:47 PM
I've always stuck with Techron. Works well so no reason to try something else. But there have been owners here that have used Seafoam and seem to like it too.
Old Aug 28, 2013 | 09:51 PM
calvins's Avatar
calvins
Oldtimer
If it ain't broke, don't fix it. It's been pretty well documented that the Techron works. Just for me anyhow, I'll stick with a known vs an unknown.
Old Aug 28, 2013 | 10:17 PM
envyz06's Avatar
envyz06
I used seafoam a lot, no issues. Lots of guys on ls1tech run it that is how i found out about it. Never actually knew techron was good?
Old Aug 29, 2013 | 04:00 AM
baxsom's Avatar
baxsom
naphtha, light oil, and alcohol.
the light oil is what causes the plume of smoke, the naptha is what dissolves the carbon but it is kinda weak. I soaked a carbon crusted valve in seafoam for a week and still needed to scrape the carbon off. The alcohol is to take care of any water in the fuel. While techron still has naphtha in it, there is also Toluene present as well plus a few other solvents.
Old Aug 29, 2013 | 07:30 AM
m6 c5's Avatar
m6 c5
So would running techron through the intake do a better job at removing carbon?
Old Aug 29, 2013 | 10:27 AM
pmurray's Avatar
pmurray
I put Seafoam in my cars and lawn mover before Winter with a full tank. Is this still good?
I use “no ethanol” gas so would I still want to use Techron once in a while?
How often?
To Seafoam Engine Treatment
