[Z06] Two issues I need help with!
Old Aug 29, 2013 | 09:49 PM
envyz06's Avatar
envyz06
Default Two issues I need help with!
First half of my gauges backlights are out, this common?
Second I was driving home and all the sudden my dash beeps and my check gauges light comes on, and shows I have no fuel. I know I have at least half a tank and continue to drive home so I know I wasn't out of gas but anyone have this issue? Here is a pic bad pic from my phone, thanks.
Old Aug 29, 2013 | 10:02 PM
81c3's Avatar
81c3
Many of these cars have fuel level issues. The sulfur build up in fuels seems to effect the float mechanism in the tank. The common cure is to use Chevron Techron additive.
The dash seems like it has a bulb out which youll need to replace.. A good time to add a set of SS trim rings!!
Old Aug 30, 2013 | 08:12 AM
striper's Avatar
striper
The dash bulb is a miniature black light. I've never seen a post before where one has burnt out. Do the dealers even sell them? You'll have to remove the entire cluster to replace it which as mentioned would be a good time to do the aluminum bezel rings, a nice upgrade to the boring dash. Should take about two hours to R&R.
Old Aug 30, 2013 | 08:56 AM
magneto10's Avatar
magneto10
The techron additive works- but it might take more than one tankful to take care of.
I also believe the dealers at one point were reprogramming the PCM to help eliminate this (I don't think it worked)
Dash-issue- sorry I can't help
Old Aug 30, 2013 | 09:01 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I use Sea Foam in my ride at least once every other month. Contact Radioflyer (vendor and light guru) here on the form. He may be able to point you in the right direction on the dash lights.
Old Aug 30, 2013 | 11:07 PM
envyz06's Avatar
envyz06
thanks guys I will check it out!
Old Aug 31, 2013 | 08:35 AM
fxdl's Avatar
fxdl
I have had the fuel guage issue for about 2 yrs now. I think its that damn ethanol that caused it. I have tried all the additives and it works for awhile and then doesn't. If I get on the highway for awhile it for sure doesn't work like it doesn't like long high speed runs. Maybe in town driving shakes it loose. I've used lots of Techron and don't think it works any better than some of the others.
Even when mine works it never reads more than 7/8 full when I've just filled it up. I just rely on my trip odometer.
Old Aug 31, 2013 | 11:13 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
The dash light is not an "easy fix" The dash is illuminated by two UV florescent tubes (one on each side) The tube on the left side has gone out. It's more than likely the tube itself and not the transformer. It's a big pain to get to it as you have to remove the cluster and disassemble the cluster almost completely to access that tube.
Old Aug 31, 2013 | 11:31 PM
envyz06's Avatar
envyz06
Do you sell them or know someone who does if you do not?
Old Sep 1, 2013 | 09:20 AM
TheRadioFlyer
Supporting Vendor
Sorry, I have no idea. I think you may need a donor cluster, but I'd check with Gene A GMpartshouse to see if he knows.
To Two issues I need help with!
