[Z06] 2002 AFR help
My issue is while we were tuning I was watching the road and not the AFR gauge. Right when I punch it the AFR drops from 14.7ish down to 12.8ish then runs all the way down too 11.1 at red line, dropping as the RPMs climb. I'm not 100% sure what he changed fuel wise other than timing. The car runs strong and feels boarder line ready to roast new tires in second with a role on.
My question is: Should I be seeing 12.8 across the RPM range or is dropping down that low normal. FYI temps are like 95 degrees and super high humidity Central Florida in August.
For a N/A car, an AFR between 12.6 - 13.0 : 1 should give you best power and MBT assuming no knock retard. Your definitely fat up top from the sounds of it.
