[Z06] tire size help
Old Aug 31, 2013 | 12:16 AM
Pozesd99''s Avatar
Pozesd99'
Default tire size help
im in need of new front tires. what size tire am i supposed to get? seems like my front tires are very tall. currently im running 275/40/17. is this the correct sized tire? what would be a shorter option that will still look good and maybe even lower the front a little
Old Aug 31, 2013 | 02:01 AM
LT1_BlackC4's Avatar
LT1_BlackC4
The stock sizing for the front C5 Z06 wheels are 265/40-17s. I have seen guys run 255s or 275s instead of 265s. All depends on personal preference for what tires are available in the different sizes, if you prefer narrower or wider tires, etc... If you want the front end lowered, just lower it on the stock bolts. I have my Z lowered that way and it helps get rid of that unsightly wheel gap.
Last edited by LT1_BlackC4; Sep 2, 2013 at 12:43 PM. Reason: Remove link to different thread.
Old Sep 2, 2013 | 12:38 PM
skyavonee's Avatar
skyavonee
Your shorter options are 265/40-17 and 255/40-17. If you want the front to be lower, do it the correct way - adjust the ride height bolts.
To tire size help
