abs traction lights
Old Sep 8, 2013 | 07:52 AM
Brian 22210's Avatar
Brian 22210
Cruising
Default abs traction lights
i know it's an old subject ! but cant find my proublem on old threads abs light comes on when car is cold when car is hot no lights cleaned all grounds new battery cleaned plug on abs code showig c 1214 help thanks ps the car is a 2001 base help please other codes are 502 h c 2482 h c
Old Sep 8, 2013 | 11:17 AM
Brian 22210
Cruising
thanks this helps , codes showing are 502 hc 2482 h c
Old Sep 8, 2013 | 12:20 PM
Brian 22210
Cruising
you are correct the codes are bo502 and B2482 C1214 thank you for the help!
Old Sep 9, 2013 | 11:04 AM
3boystoys's Avatar
3boystoys
REALLY, you can't find anything??? Only dozens if not HUNDREDS of posts on the 1214 error.
To abs traction lights
