Any Autobody guys? Replacing front frame nuts
Old Sep 8, 2013 | 03:40 PM
ssbowtie1's Avatar
ssbowtie1
Default Any Autobody guys? Replacing front frame nuts
While removing the brackets, I noticed that two of the nuts that are pressed into the frame were spinning freely. I ordered two pieces, but I don't know how to install them. Do you just pop the old ones out and hammer the new ones in?
Old Sep 8, 2013 | 04:51 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I could be mistaken, but they look like a threaded insert called a 'riv-nut'. If so, they are installed like a pop rivet. There's a tool that has a male threaded tip on it, you screw the riv-nut onto it, place the riv-nut into the hole, then squeeze the handles of the tool until the insert is swaged into the frame.
Old Sep 8, 2013 | 05:04 PM
Patches's Avatar
Patches
Old Sep 8, 2013 | 05:40 PM
Phanni's Avatar
Phanni
These are used throughout the C-5,, contact a C-5 recycler, he'll have a bagfull.
Old Sep 8, 2013 | 05:45 PM
ssbowtie1's Avatar
ssbowtie1
Thanks guys.
I will drill out the loose nuts and Riv-Nut the new ones in place.
Old Sep 8, 2013 | 06:45 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by ssbowtie1
Thanks guys.
Be Careful!!
In order for the new riv-nut to be able to be swedged into place, the hole has to be a specific diameter.
To Any Autobody guys? Replacing front frame nuts
