[Z06] No Powa!
Old Sep 11, 2013 | 10:33 PM
VetteGirl7799's Avatar
VetteGirl7799
Default No Powa!
Just bought an 02 Z06 last month, knew it had a few issues but Ive been working them out. The car seemed like it has had full power up until the last few weeks its been really down on power and revs increase very slowly when accelerating. The only codes are for the rear O2 sensors which have been on since I bought it. I cleaned the MAF and checked for vacuum leaks on the intake tube but that didn't help anything. Any ideas on what could cause this?
Old Sep 11, 2013 | 11:51 PM
81c3's Avatar
81c3
Clogged fuel filter, or a weakening fuel pump perhaps? Have the fuel pressure checked out.
Old Sep 12, 2013 | 12:05 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Clogged cats
Old Sep 12, 2013 | 10:20 AM
VetteGirl7799
These are both things I was considering. Yesterday I dropped the H pipe and replaced the fuel filter with an AC Delco unit. Is there anyone who makes a bolt in offroad H or X for these? All Ive seen is the Magnaflow piece that I think you have to cut the factory H portion off and reuse. I guess theres not much of a way to visually check the cats without cutting the H pipe?
Old Sep 24, 2013 | 03:10 PM
VetteGirl7799
The old cats had been gutted by the previous owner. Replaced the H pipe with a low mileage factory unit off another Z06. Still getting the 0420 and 0430 codes. I guess the sensors are bad? Still down on power under WOT. These codes don't cause any sort of limp mode do they? Any other ideas?
Old Sep 24, 2013 | 11:50 PM
PeteZ06's Avatar
PeteZ06
I would replace the sensors and take it from there...
I'm not sure if it causes the car to go into limp mode.. but I wouldnt rule it out..
Old Sep 24, 2013 | 11:54 PM
Supercharged111's Avatar
Supercharged111
AFAIK, the rear O2s only affect fueling if they think the cats are overheating.
To No Powa!
