Removing Flush Mounted Tail Lights
Old Sep 13, 2013 | 09:51 PM
SlowFRC's Avatar
SlowFRC
Default Removing Flush Mounted Tail Lights
I just got an 02 Z with flush mounted tail lights. I'm not a fan of the look at all. To return the lights back to the stock recessed look do I need to buy stock brackets or is there just a spacer that I can remove from behind the light that pushes it further forward?
I know the question is pretty basic and I could probably just take the light apart and figure it out but if there's some stock brackets or something else I need to buy first I'd rather do that before taking things apart.
Old Sep 13, 2013 | 09:57 PM
LoneStarFRC's Avatar
LoneStarFRC
No "brackets", just remove the spacers.
Note: You WILL however, need the OE stock screws to replace the longer ones used in these "flush" kits. If I were you, I would have these on hand before dismantling.
HTH
Old Sep 13, 2013 | 10:21 PM
Easy mod to reverse.
Old Sep 13, 2013 | 10:26 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Good move. I tried that same mod but thought it made my Corvette look like a Cobalt.
Old Sep 13, 2013 | 10:30 PM
MotoJB's Avatar
MotoJB
Same thing...had the flush mounts for a couple weeks before I removed them. Part of the corvette's character is the recessed tail lights. I hated the flushies. Worst part is the dang flush mount seals I put in also kind of scratched the paint.
Old Sep 13, 2013 | 10:54 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
#8 machine bolts fine thread
Peace
Chip
__________________
..................Click for
Old Sep 14, 2013 | 12:41 AM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
I just reused the longer screw without the spacer did not see anything behind there that would cause a problem.
Old Sep 14, 2013 | 04:10 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I agree. You'll also forever be cleaning the new recesses. They love to collect dirt and debris
To Removing Flush Mounted Tail Lights
