[Z06] Valve cover leak
Old Sep 20, 2013 | 02:14 AM
808EB03Z06's Avatar
808EB03Z06
Default Valve cover leak
How common are these? Mine started leaking a fair amount of oil yesterday and I have never had a car do that. Gaskets were replaced about 18 months ago when the build as done. The only reason I have any real concern is that right before I noticed the smell of oil burning I was changing lanes fairly aggressively and when i shifted from second to third, the RPMs jumped and i'm not sure if it over revved or not cause it was so damn fast. Thanks for any help.
Old Sep 20, 2013 | 05:14 PM
RedZMonte's Avatar
RedZMonte
just like any seal they can dry, pinch or be installed improperly.. easy job to do.. I would get Felpro gaskets (Blue ones) and make sure you clean both surfices well. some people use a little dab of gasket sealer to hold it in place for install but it makes a mess and i end up wiping it off anyhow.
Old Sep 20, 2013 | 06:51 PM
racebum's Avatar
racebum
were the covers cleaned and torqued properly to start with?
Old Sep 20, 2013 | 08:40 PM
JoeJ's Avatar
JoeJ
Mine did the same thing after changing the valve springs. The heads had some light tooling marks where the valve cover seated. I suppose they were not clamped down good when they were finished milled. Regardless, I had to use some 220 wet dry and polish the flat where the gaskets seal on the head. Problem fixed.
Old Sep 21, 2013 | 01:33 AM
808EB03Z06's Avatar
808EB03Z06
The gasket was definitely blown out. I just wanted to make sure that nothing else was a possibility. Is there a specific PN for the Fel-Pros since I have aftermarket heads, or would it be the same for a stock head? Thanks for the info.
Old Sep 21, 2013 | 11:37 AM
ZZOOM06's Avatar
ZZOOM06
They are the same, I have the blue Fel-Pros on my car with AFR heads.
You can get them at Auto-zone or O'reillys and they are not expensive.
Sorry. don't have a part # for you, just ask for gaskets for any LS1/6 and it will fit.
Old Sep 21, 2013 | 01:11 PM
racebum's Avatar
racebum
does the engine have a lot of blow by? the only time i've seen a valve cover gasket actually blow out on a motor was one that had a LOT of crankcase pressure due to blow by
Old Sep 21, 2013 | 02:08 PM
808EB03Z06's Avatar
808EB03Z06
I don't think so. It happened after to the tires spun really hard on a quick shift the other day, and the only thing I could think of is the rpms jumping so fast might have caused some added pressure. Otherwise I have no idea what could have done it.
To Valve cover leak
