Gauge Failures odd issue
Old Jan 19, 2014 | 09:46 PM
ultradriver10000's Avatar
ultradriver10000
I pulled them out and tried cleaning them with a little brake cleaner. Maybe I need to do a better job.
Old Jan 20, 2014 | 09:34 PM
sn8bite's Avatar
sn8bite
Try an Emory board on the contacts. Make sure you get all of the corrosion off, then clean them with MAF cleaner. Use dioelectric grease to keep out moisture and dirt.
Old Jan 20, 2014 | 09:38 PM
sn8bite's Avatar
sn8bite
Also do a search on corrosion issues with the c5,there are grounds that get corroded and will cause all kinds of issues like the ones you are having.
