Glue
Old Sep 23, 2013 | 08:37 AM
Youngchris's Avatar
Youngchris
Default Glue
Good Morning,
One of the flags on my front emblem is raised up and I want to re-glue it down. What is the best type of glue to use on this. i apologige for this probably being a silly question but I want to do it the correct way and I know that you all have the best answers.
Thanks!!
Old Sep 23, 2013 | 09:08 AM
CHJ In Virginia's Avatar
CHJ In Virginia
The emblems are not glued down to the car. Glue would have bad effects on the paint if the emblem was ever removed or replaced. The factory uses a very thin double sided sticky tape. Check out various forum vendors such as Ecklers or Mid American for the product.
Old Sep 23, 2013 | 09:10 AM
Youngchris's Avatar
Youngchris
Thanks very much. I will contact the vendors you provided.
Old Sep 23, 2013 | 11:51 AM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
The front emblem also has two prongs that fit into holes in the hood.
It sounds like one of them may have broken?
dan k.
Old Sep 23, 2013 | 12:04 PM
Youngchris's Avatar
Youngchris
Thanks Dan, I will check it out
Chris
Old Sep 23, 2013 | 12:08 PM
dork's Avatar
dork
Just get some double-sided sticky tape, a razor blade and some alcohol wipes. The tape at Lowe's or HD is thin enough. Clean both surfaces thoroughly, cut around your emblem with the razor and install.
The tape I bought at Lowe's matched the thinness of the other tape used for the lettering that was still intact, so the thickness of the tape shouldn't be a concern.
Old Sep 23, 2013 | 12:15 PM
Youngchris's Avatar
Youngchris
Thanks!!
Old Sep 23, 2013 | 10:45 PM
Double sided tape holds the entire emblem to the front of the car, but the inserts that go in the emblem are held in place with glue. Not sure which part has come loose, but if the emblem itself is lifting, 3M double sided tape will stick it back on.
Old Sep 23, 2013 | 10:50 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
This is the correct reply...
Old Sep 24, 2013 | 12:35 AM
dork's Avatar
dork
Mr. B's right. It never occurred to me that the flag in the emblem was peeling. If that's the case, you'll need to glue it.
I'd mask t'hell out of the area before I'd drip glue on the painted surface, or take the emblem off to glue the flag.
Old Sep 24, 2013 | 08:09 AM
Youngchris's Avatar
Youngchris
Thanks Jack. Bill and Dork.
Your advice is well taken.
To Glue
