[Z06] Valve Spring Replacement
Old Sep 25, 2013 | 08:50 PM
JBoyle997's Avatar
JBoyle997
Default Valve Spring Replacement
Hey guys,
After researching on the forum...I will be Dropping my 02Z off at ECS in about 2 weeks to have the valve springs replaced. They are going to replace them with Manley beehive single coils. I ordered MSD wires and NGKTR55 plugs to have them do as well while its apart. Does this sound good to you guys? Good spring choice? Anything else they should look at? Only mods to the car is a Vararam intake. No cam or anything in the near future for me. Thanks, John
Old Sep 26, 2013 | 01:04 AM
ZeeOSix's Avatar
ZeeOSix
I'd have them check to make sure all the pushrods are straight and that the rocker arm bearings are all intact. You might as well get the Comp Cams trunnion kit and have them install that too while in there. The stock rocker arm needle bearings have been known to be a weak link also ... but not as bad as the valve springs.
Old Sep 26, 2013 | 09:44 PM
Sportsman2003's Avatar
Sportsman2003
I just had my springs and trunnion bearings replaced.
I also had them do the valve seals as well.
Old Sep 28, 2013 | 10:39 AM
SinisterZ06vette's Avatar
SinisterZ06vette
i brought valve seals to my valve spring install and we detirmined they were un-needed as long as yours dont look like wood
Old Sep 28, 2013 | 11:02 AM
bumble-z's Avatar
bumble-z
You are doing all the right things.
Your car is over 10 years old, it only makes common sense
to replace those parts while in there.
As mentioned before, your car is in the very best of hands.
Oh, and you will love those springs that they are installing.
I swear after I installed them in my LS/6, that the Red Line hit so much faster that I raised the red line to around 150 - 200 RPM's higher.
Old Sep 28, 2013 | 11:17 AM
JBoyle997's Avatar
JBoyle997
Thanks for all the great info guys, I'm pumped!
To Valve Spring Replacement
