fast 102mm users please help
Old Sep 26, 2013 | 06:28 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default fast 102mm users please help
OK i have searched a little i work 14 hrs a day so i thought i would just ask to simplify .
I'm going to be running a fast 102mm intake and a NW 102mm throttle body and a tsp 100mm mass air flow, will this work with the vararam or should i get a new air intake? (
if so which one ?)
where to get couplers?
anything else i would need
thanks
Old Sep 27, 2013 | 09:56 AM
didntdoit11
St. Jude Donor '12
76 views and no help I must be the first person to think about it or do it
Old Sep 27, 2013 | 06:12 PM
calivette805's Avatar
calivette805
I would think you only need couplers .silicone intake sales has a bunch for good prices
Old Sep 27, 2013 | 06:31 PM
silver408z's Avatar
silver408z
It should work but you will probably have to find couplers depending on sizes of the tubing and TB. I have the NW 102 and it was larger than my air bridge. I could not find a coupler that had the right size on both ends. I learned that some silicon is reinforced with fibers and some is not. This is important for forced induction because they can make the couplers pop if its not reinforced. Since my engine is N/A and the section I needed was very minimal I used a piece that is not reinforced. The coupler only seals the joint for me and does not actually fill in any space between tubing. With a piece that was not reinforced I was able to stretch it over the TB and it already matched the air bridge I had.
Old Sep 27, 2013 | 06:34 PM
Biomech011's Avatar
Biomech011
I will be running the same set up. I had just Returned my TSP Mass Air Flow,
because the Haltech Killer Bee II includes the integrated probe style LS7/LS3/LS9 MAF sensor.
The whole intake system is 102mm.
That's 102mm all the way through with no steps nor air flow Restrictions.
Here have a look this is the set up I am running:
http://www.halltechsystems.com/product-p/kbls6conv.htm
Old Sep 27, 2013 | 08:12 PM
didntdoit11
St. Jude Donor '12
Thank you
To fast 102mm users please help
