Performance question
Old Sep 29, 2013 | 08:11 PM
Americandreamer06's Avatar
Americandreamer06
2nd Gear
Default Performance question
Hey guys quick question..I have a 99 c5 vette..I brought about a year ago with 100k miles..it has about 125k now..my question is it ok to add aftermarket performance parts to it with it being a high mileage engine and all?
Old Sep 29, 2013 | 09:00 PM
sfc rick's Avatar
sfc rick
I added heads and cam at 91,000 then at 135,000 added a supercharger. These engines are just getting broke in at 100,000 miles.
Wrench on it and have a good time doing it!
If you have doubts, do a leak down test on each cylinder, check your oil pressure, change the oil and look at the old oil and see if it has metal in it, if not rock on!
Old Sep 30, 2013 | 11:10 AM
Americandreamer06
2nd Gear
How exactly would I need to perform this test
Old Sep 30, 2013 | 11:21 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Spend the money on flying lessons. Much bigger thrill. Who cares if 0-60 is slightly better after spending $10,000........Big deal! Still just a boring car relegated to the surface of the earth.
Old Sep 30, 2013 | 11:36 AM
JetMechZ16's Avatar
JetMechZ16
So you can fly in a jet doing over 500 kts and not even know you're moving. How is that exciting??
Now if it has an afetrburner, well that's something different altogether
Old Sep 30, 2013 | 12:26 PM
slocobra's Avatar
slocobra
Used to be fun to fly...until I got cars that pulled harder than the planes taking off.
Old Sep 30, 2013 | 01:34 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
In short - YES!
There are many things you can do to it -
LT Headers and hiflow cats and Xpipe -
C5 Z06 TI Mufflers or another aftermarket set (B&B Fusion)
Heads and Cam
LS6 manifold
Ported and Polished TB
VARARAM
Dyno tune
That will net you a cool 430+ RWHP and still get great MPG
TRUE BOLT ON: Most performance dollar for dollar!
However a simple and easy bolt on would be a supercharger and with your miles you should keep it at 8-10 PSI of Boost and you will have 500+ RWHP and cost about the same or little less than the above list!
Thanks,Matt
Old Sep 30, 2013 | 04:16 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Can a average guy afford to own a plane??????????
Old Sep 30, 2013 | 04:33 PM
oldschoolvette's Avatar
oldschoolvette
no
Old Sep 30, 2013 | 04:43 PM
Ole Blaster's Avatar
Ole Blaster
Old Sep 30, 2013 | 05:28 PM
cramar's Avatar
cramar
Originally Posted by madmatt9471
In short - YES!
Heads and Cam
LS6 manifold
VARARAM
Dyno tune
Thanks,Matt
This raises some questions. Would you not want to at least upgrade your intake and exhaust if putting on a supercharger? Do you really want to use the stock set up with a superchanger? Also wouldn't a dyno tune be advisable to get the most benefit?
Old Oct 1, 2013 | 12:41 AM
If the car is in good mechanical condition, performance upgrades should be OK.
To Performance question
