[Z06] it happened!!!(long post)
Old Oct 8, 2013 | 10:17 AM
bob22z06's Avatar
bob22z06
Default it happened!!!(long post)
It happens to the best of us I should say ..I was driving home last night , running low on fuel so I pulled in to gas station, fueld up ..started the car , put it in gear started to let go off the clutch ..car moved like a foot..bumm!!! Car stalls. ..I'm like what ?!! I thought I didnt give enough gas...and I wasn't looking at the dash too...so I try again ...bumm..moves a little and stalls again ...then I look at the dash it showes the message" battery fault and something els and 10sec pull key "message .I did that started fine and I went home ..Got home and ordered the LMC5 ...I kind of knew I didn't have one installed in my Z because my stearing wheel looks every time I take the key out ...I figured ill be ok for while since I don't really drive the car out of town..Now I learning my lesson here this kind of thing can happen anytime ...I take few steps back how I think this happened. Maybe becuse since it got cold very quick made the battery lose its power and that trigered it..one more thing.I noticed when I took the key out when I got to the gas station my seat moved back like it usually does and when I got back in and put the key in it the seat didn't move, so I took the key in and out and turned the ignition on position and still didn't work ..What u guys think causing this is??? it something in the ignition or its the memory module ? Be glad to have your guys input in this .thanks
Old Oct 8, 2013 | 02:09 PM
Cucho03's Avatar
Cucho03
I'm not an expert but I experienced the same symptoms about 8 or 9 months ago after washing the car while listening to the car radio. I am guessing that the battery voltage went south. My car has the anti-locking device installed by previous owner. I will never ever again listen to the car radio while the car is not running.
