3D-Printed HUD Dimmer Knob...
Old Oct 10, 2013 | 12:06 AM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
is it a HUB or HUD ?
Old Oct 10, 2013 | 08:39 AM
dadaroo's Avatar
dadaroo
Dan, tried to email pictures via the Forum but could not attach without using a web service which compresses them. PM me with your email address and I will send. If you want to make a functional non original looking **** the pictures I made/can make will do. Frankly with all the compound curves on top and bottom I don't see how you can really do a OEM looking one by pictures. My pictures are against a 2mm X 2mm graph grid to assist. If I had a laser scanner it would be a piece of cake.
Old Oct 10, 2013 | 11:08 AM
DanSavage's Avatar
DanSavage
Originally Posted by Dave68
By the way, nearby is a local shop called "MakerPlace". It contains almost everything a hobbyist could want, including electronics stuff like Oscilloscopes, variable power supplies, soldering equipment and even function generators. There are CNC mills, lathes, sheet metal presses/sheet metal equipment, abrasive machines, woodworking equipment, 3D printers, laser cutters, spray booths, fabric and sewing equipment, etc, etc. You pay daily, weekly, monthly, or yearly, I believe, although I don't have pricing. Our local SME chapter will be planning a tour of this place, soon. I'll be sure to attend.
Thanks for the kind words.
I looked at their web site and they are fairly close to me down in San Diego, CA. They do have an impressive array of equipment and software available which would allow a wide variety of things to be designed and manufactured on-site.
Old Oct 10, 2013 | 12:23 PM
DanSavage's Avatar
DanSavage
I got the pics you sent and after looking at them I've come to the same conclusion as you. It's going to take having a physical **** in front of me to make an accurate model of the OEM ****.
Since Lee DeRaud is pretty close to me, mailing the **** back and forth between us will only take a day each way. So, I think I'll take him up on his offer to use his as a model.
Thanks again,
Dan
Old Oct 10, 2013 | 12:30 PM
DanSavage's Avatar
DanSavage
The **** we're talking about goes to the dimmer slider on the HUD (Head-up Display) control panel.
One of the models I made in the sample screen shots and photos I posted using 3D printing is a HUB cap for an R/C F-111.
Old Oct 11, 2013 | 07:43 AM
dadaroo's Avatar
dadaroo
That's fine Dan. If case you need me to send you mine I will leave it off until you have all the info you need.
Old Oct 11, 2013 | 09:45 AM
Former Vendor
gotcha,
Old Oct 22, 2013 | 10:00 PM
DanSavage's Avatar
DanSavage
I've finished the 3D model. Here's a couple of pics of the original and one of the model I built from it.
Interestingly, there is a teeny-tiny spring that goes inside the recess in the back of the **** that keeps it in place.
The lines in the photos are 1/2" apart, so you can see how small these parts really are.
Since I can't make the spring, I've reduced the size of the holes so they are about the same size as the prongs that stick out of the HUD dimmer.
I uploaded the 3D model to Shapeways.com so I can get one printed. Once I get it back from them I can test the fit and make the necessary adjustments.
Old Oct 22, 2013 | 11:21 PM
Choreo's Avatar
Choreo
Impressive, but I am expecting that someday we will be flooded with posts from people who have found their long lost ***** taking up residence in some obscure location... I am pretty sure they are not flying out the window! Right now they are in the same category as the missing sock in the dryer.
Old Oct 23, 2013 | 12:33 AM
DanSavage's Avatar
DanSavage
Thanks!
They might find the ****, but finding that teeny-tiny spring is a horse of a different color...l
Old Oct 23, 2013 | 01:58 AM
Lee DeRaud's Avatar
Lee DeRaud
Just as long as you don't lose that one...
Old Oct 23, 2013 | 07:05 AM
dadaroo's Avatar
dadaroo
Looks good Dan. Without the spring if it were me, I would just use some silicone sealant to help secure the ****.
Old Oct 23, 2013 | 10:59 AM
  #33
DanSavage's Avatar
DanSavage
Yeah, no foolin'.
Actually I didn't know it was there until I happened to look in the baggie and saw it. Then I wondered what it was and in messing around with the **** saw how it fit into the recess. And, it's not a pressure fit inside the ****. If you didn't know about it, it could easily fall out and be lost to the ages.
After that, I carefully put it back in the baggie and I'm now careful to make sure it was still there every time I took the **** out of the baggie.
I tried the **** without the spring and like Mr. Sam says, you would need some sort of glue to keep the **** in place.
Old Oct 23, 2013 | 11:05 AM
  #34
DanSavage's Avatar
DanSavage
Yeah, I agree. The fit is pretty slopping without the spring.
I made the recesses in the 3D **** the same size as the two dimmer slider posts.
That should be the only part of the **** that would need adjustment.
Old Oct 23, 2013 | 12:42 PM
  #35
DanSavage's Avatar
DanSavage
BTW, did you know the spring was in the **** when you sent it to me?
Old Oct 23, 2013 | 12:43 PM
  #36
Lee DeRaud's Avatar
Lee DeRaud
And I'm one of the people who didn't know it had a spring...glad I used that baggie.
I must have had that **** on and off a half-dozen times when I was dialing in the fit of the acrylic blank, and it never fell out.
Old Oct 24, 2013 | 07:00 AM
  #37
dadaroo's Avatar
dadaroo
Dan, when I pulled mine off for you I saw it had a spring in it. That was one reason I thought you needed an OEM **** to duplicate. My spring is in there securely. It appears to be a slightly different design than the one you have but similar since the lever has 2 prongs that go into the ****.
To 3D-Printed HUD Dimmer Knob...
Old Oct 24, 2013 | 01:03 PM
  #38
DanSavage's Avatar
DanSavage
My dimmer slider also has two prongs.
The **** Lee sent has a single hole with a blade that comes out from one side of the hole and extends about 3/4 the way across the center of the hole.
The spring goes on the open side of the hole and presses against the prongs to keep the **** in place.
Yeah, you were right about needing an OEM **** to model. The shape is very unusual. It would have been very difficult to duplicate from photos, but was fairly straightforward once I had it in my hands and was able to analyze the shape with my own eyeballs.
Old Oct 24, 2013 | 01:07 PM
  #39
DanSavage's Avatar
DanSavage
Yeah, too am glad you used a baggie. I didn't know it had a spring either until I saw it sitting in the bottom of the baggie.
If it had fallen out in the envelope I would have never seen it and neither of us would have known it was missing until after I sent the **** back and you went to put it back on the car. Then you would have wondered what I did to your **** to make it not fit any more. (Honest, Lee! I didn't break your ****! )
Old Oct 25, 2013 | 08:19 AM
  #40
mre1974's Avatar
mre1974
If you get a working version that you can print are you planning to potentially sell them? I know that I sure would love to get a hold of a new HUD dimmer ****. When I bought my '99 FRC I didn't have one and haven't been able to source one without buying the whole unit. Your prototype sure looks promising. I'd happily be a guinea pig if you need one.
