Seat memory with key.
Old Oct 12, 2013 | 10:23 AM
Ekul61's Avatar
Ekul61
Default Seat memory with key.
Is there a setting that returns your seat to the driving position when you put the key in the ignition?
Old Oct 12, 2013 | 10:46 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Memory setting #1.
Old Oct 12, 2013 | 11:01 AM
Lee DeRaud's Avatar
Lee DeRaud
I wish.
The seat memory function in GM cars (at least of that era) is kind of retarded. You can set it so it goes to a "easy exit" position when you take the key out, but it returns to the position associated with the key fob when you use the fob to unlock the door...before you get in. About the best you can do is set that position to match the exit position and, as c5vetteguy said, use another memory to (manually) move it back while you're starting up.
But another thing to consider is the wear and tear on the mechanism. Like the Twilight Sentinal, which tends to wear out the headlight motors prematurely by turning them on every time you start up in the garage, the constant back-and-forth of the seat is probably a contributor to the infamous "rocking chair" bug. And, at least in my car, the noise the seat makes rubbing against the seatbelt covers is very annoying.
Old Oct 12, 2013 | 11:18 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Originally Posted by Lee DeRaud
I wish.
There's something wrong with yours. Mine - and everyone else's I know - works perfectly. Key out = seat back. Key in = seat forward. I always use the FOB to unlock and it never moves the seat.
As for wearing out prematurely, you're going to see a lot of posts after mine stating no excessive wear from guys who have always used it.
I will give you the fact of the noise issue though!
Old Oct 12, 2013 | 11:29 AM
c5vetteguy's Avatar
c5vetteguy
I should have been more explicit. As Lee mentioned, you don't want to use the "easy exit" mode.
Set your driving position to memory setting #1. When you unlock your car with the fob and then insert the key in the ignition, your seat will automatically go to the driving position.
Move your seat all the way back and set memory setting #2. When you want out you need to hit the #2 button.
As long as you lock and unlock with the fob, you won't need to push the #1 button.
Old Oct 12, 2013 | 01:28 PM
Lee DeRaud's Avatar
Lee DeRaud
(hangs head) You're right, I'm thinking of my GF's '04 Buick, which actually needs that function as I can barely get in when the seat is set for her. It was that godawful noise that made me shut it off in my car about 30 minutes after I bought it.
Old Oct 12, 2013 | 01:36 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I find mine doesn't return to Memory 1 all the time and I end up pressing the button.
Could it be a fob battery issue?
Old Oct 12, 2013 | 01:47 PM
Lee DeRaud's Avatar
Lee DeRaud
Possibly, but if the fob battery works well enough to unlock the door, that's about as good as that battery gets. And I suspect you still need to use the fob to unlock the car or the seat won't know which memory to use.
Old Oct 12, 2013 | 02:40 PM
Ekul61's Avatar
Ekul61
Yes it did work. But if you don't lock the car with the key fob .the memory won't work. So if you never lock your car with the fob. The memory won't work when the key is put in the ignition.
Old Oct 12, 2013 | 04:30 PM
c5vetteguy's Avatar
c5vetteguy
That is correct. In that case just hit the #1 button. Not too much to ask.
Old Oct 12, 2013 | 05:16 PM
Chilliwack vettes
The seat will also not move if you have the door open when you insert the key.
Old Oct 12, 2013 | 05:57 PM
Jeff T.'s Avatar
Jeff T.
Good to know, Thanks!
Old Oct 12, 2013 | 09:22 PM
Mine works that way too.
Old Oct 12, 2013 | 11:12 PM
allred's Avatar
allred
I do know this.................................... .
1) If you are using key fob #1, if you lock the car, when you unlock the car and insert key #1 in the ignition, your seat will automatically move to the #1 position.
2) If you are using key fob #2, if you lock the car, when you unlock the car and insert key #2 in the ignition, your seat will automatically move to the #2 position.
3) You can program your seat to move to the fully-back position when the ignition is on and the engine is running, by pressing both seat position #1 and seat position #2, buttons simultaneously.
4) If you do not lock your car, when you insert either key #1, or key #2, in the ignition, neither key will be recognized and you will need to press either the "position #1" button, or the "position #2" button, to move the seat to its appropriate pre-set position.
5) You do have to program seat position #1, seat position #2, and seat position #3, for them to work.
Old Oct 13, 2013 | 01:26 AM
65GGvert's Avatar
65GGvert
1) If you are using key fob #1, if you lock the car, when you unlock the car and insert the key fob #1 in the ignition, your seat will automatically move to the #1 position.
2) If you are using key fob #2, if you lock the car, when you unlock the car and insert the key fob #2 in the ignition, your seat will automatically move to the #2 position.
4) If you do not lock your car, when you insert either key fob #1, or key fob #2, in the ignition, neither key will be recognized and you will need to press either the "position #1" button, or the "position #2" button, to move the seat to its appropriate pre-set position.
I'd agree with all that except for "inserting the key fob in the ignition". You'd use the fob to unlock the car, then stick the KEY in the ignition.
Old Oct 13, 2013 | 11:24 AM
allred's Avatar
allred
Point taken, post edited to avoid any confusion, I wouldn't want someone to spend time struggling to force the rounded end of their key fob into the ignition switch.
Now, is anyone going to tell me that the keys are not number #1 and #2, but it is the key FOBS that are number #1 & #2.
Old Oct 13, 2013 | 01:54 PM
allred's Avatar
allred
Originally Posted by 8VETTE7
I did notice that but didn't want to raise a ruckas so I won't mention it........
LOL....thanks 8VETTE, we'll just keep it to ourselves.
To Seat memory with key.
