which cold air is this ??
Old Oct 13, 2013 | 02:01 PM
gmbal4's Avatar
gmbal4
Default which cold air is this ??
bought my vette and it came with this cold air on it can someone tell me which cold air kit it is ??
[IMG][/IMG]
Old Oct 13, 2013 | 02:03 PM
Ole Blaster's Avatar
Ole Blaster
[IMG][/IMG]
I don't no the name... I see them on Ebay $60.00 and up...they have both black and chrome..
Old Oct 13, 2013 | 02:29 PM
gmbal4's Avatar
gmbal4
does anyone know if this add any extra HP to the car or should I buy something more of a brand name ?
Old Oct 13, 2013 | 04:18 PM
Ole Blaster
tuner said it was fine,,, the top center of the filter is open instead of the sealed chrome top... your name brand will cost big $$$$.. and yes it will breathe much better,, picking up the HP...
Old Oct 13, 2013 | 06:46 PM
racebum's Avatar
racebum
i remember those that's old school. what people found out is they actually cost you power versus the single element blackwing style. the way those twin cones are setup air is rushing in from both sides and creates turbulence where it hits
i doubt you would lose anything going to a 2002 z06 box with an amsoil or k&n filter. sure would be more secure in wet weather too
the vararam seems to make the most power but it's not one i would want to drive in the rain.
if you decide to change it do some reading up before you buy
Old Oct 13, 2013 | 06:53 PM
sbulla's Avatar
sbulla
I don't think you can technically call that a "cold" air intake if it doesn't draw air from outside the engine compartment.
Sonny
Old Oct 13, 2013 | 10:35 PM
gmbal4's Avatar
gmbal4
thanks guys
Old Oct 14, 2013 | 01:10 AM
Brad S.'s Avatar
Brad S.
It looks like the air intake that Mid America Motorsports sells new for $169, but there are a lot of other ones off ebay that are "look-a-likes".
Old Oct 14, 2013 | 10:11 AM
striper's Avatar
striper
I guess some people like them because they look different and custom. As far as performance, I remember reading the same thing about them.
Old Oct 14, 2013 | 12:34 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I warned you not to drink the koolaide. I drive mine in the rain, I drove mine in a tropical storm. I've never thought of it as a submarine, so I highly doubt I'll see my motor hydrolock. Is that your fear?
Old Oct 14, 2013 | 02:44 PM
racebum's Avatar
racebum
that's the fear of any snorkel intake, they can suck up water and send it straight to the engine. other thing that bugs me about all the cold air intakes really is that they are bottom feeders and suck up a ton of debris versus the under hood style.
i guess some folks don't mind, however, if i had to choose a $400 mod on a stock car it would probably be the GM hot cam versus a vararam. the hot cam will pop a stock z06 a solid 30hp and doesn't require a spring or pushrod change. very easy to tune too.
Old Oct 14, 2013 | 09:09 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
THe aftermarket filters are all junk. They certainly don't cool the air. What baloney!!
Old Oct 15, 2013 | 12:54 AM
yaknow's Avatar
yaknow
simple rainfall will never hydro lock a vararam. Driving in 12" probably will but, you'll also flood the interior of your car and destroy the electrical system and computer on the passengers side of the car
Old Oct 15, 2013 | 02:55 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Forget about all of that Just got verification from Vararam that they don't have CARB certification so looking forward to the smog test.
Old Oct 15, 2013 | 03:17 AM
racebum's Avatar
racebum
i admit i'm skeptical mostly due to seeing what bottom feeders suck up in hondas. way way back when i worked in a shop during the ricer days guys would always put a long tube on a honda down in the fender well. the amount of leaves, grime and crap on the filter was pretty substantial.
if i only drove a couple thousand miles a year in mostly dry weather i would get a vara. around here some of the puddles turn into mini swimming pools and it's very possible to get a large amount of water in the front ducts. if that happens under any sort of throttle you will have just ingested water. it really doesn't take a lot to pop a motor
i just think there are safer ways to make hp. i mean, it's an LSx, you sneeze at them and gain 10hp
Old Oct 15, 2013 | 05:10 PM
Ole Blaster
Its a cheaper version of BBK,, Volant ect. my tuner said don't believe the stuff written about the "turbulence"... it's not a straight Tee shaped intake... you can use the K&N filters for max flow,, there low filtering for higher air flow. .
Old Oct 15, 2013 | 06:22 PM
Ole Blaster
you have to use the Co2 style air filters....
To which cold air is this ??
