Modifications
Old Oct 14, 2013 | 05:36 PM
eugenecruz's Avatar
eugenecruz
Cruising
i really appreciate your advise, very informative.
Old Oct 14, 2013 | 05:53 PM
eugenecruz's Avatar
eugenecruz
Cruising
excellent info.
Q. the T rex cams was recommened to by a friend that had one, comp cams recommended this one- 228/230-.571/.573 LSA 112, so basically what you (TECH and racebum) are saying is that i am better of with a lower cam for what i want to do?
thanks, very good detailed info.
Old Oct 14, 2013 | 05:57 PM
Tech's Avatar
Tech
There are a number of shops that specialize in LS1 engines. Give any one of them a call and chat with 'em.
If you're looking for help to get started, you can try calling Texas Speed or Speed Inc. Links below.
www.texas-speed.com
www.speedinc.com
Old Oct 14, 2013 | 06:53 PM
Blow Torch's Avatar
Blow Torch
Originally Posted by WKMCD
They are both wear items. The LS7 lifter is now the standard replacement lifter for LS1/2/6/non DOD LS3's. They are about $130 IIRC. The buckets are there to keep the lifter from turning sideways in the bore - which is very very bad. The buckets are a couple $$ each and cheap insurance.
Why replace them now? You're in there anyways and if the bigger cam stresses the originals and they have to be replaced, you have to take the heads off to get to them.
I questioned it because I asked the cam builder/designer that I am getting my next cam from, if I needed to replace the lifters and buckets (60,000miles) and he said "no need"
Old Oct 14, 2013 | 07:15 PM
WKMCD's Avatar
WKMCD
[QUOTE=Blow Torch;1585175373]I questioned it because I%2
Old Oct 14, 2013 | 07:20 PM
WKMCD's Avatar
WKMCD
Originally Posted by eugenecruz
ok, so how about this one?
FWIW: I ran a 230-236 112 +2 XE-R lobed cam in my 346 build. The car made 460/424 and was extremely drivable. That was with heads comparable to what you will be running. I took it on long trips and used it to commute here in Washington, DC rush hour and it ran like a raped ape WFO. This was with a well ported FAST 90/90 setup.
I sold that top end and cam to my bud JACKS996 here and he got the same numbers on his build.
BTW: Brian Tooley has some very good springs at a very good price.
http://www.briantooleyracing.com/660...retainers.html
Old Oct 15, 2013 | 10:50 AM
Kreeess's Avatar
Kreeess
this is actually a descent set up cam i have a custom cam grinded down similar to this and the car pulls awesome through out the powerband, one thing about cams i learned is that you have to know where you want your power to be at, there are some cams that give better torque and some cams that give out better top end, it really comes down to what YOU want for your car, sound will come with your exhaust and headers cam choice should be based on how your going to drive your car and how you want it to breathe. hope this helps
Old Oct 15, 2013 | 11:18 AM
Kreeess's Avatar
Kreeess
heres a clip of my custom cam
Old Oct 15, 2013 | 05:16 PM
cammedvette's Avatar
cammedvette
Seems I have about your exact set up.. LS6 Heads...LS6 intake ...Long Tube Headers..high flow cats...Corsa Catback....Good street tune..I am running a Comp Cams 230/232 with .595 lift on a 110 LSA. Car runs great.. pulls really strong..has choppy idle.. sounds really mean.. very drivable...and gets 29 mpg on the highway!!!
Perfect street cam imho...
Old Oct 15, 2013 | 05:39 PM
Kreeess's Avatar
Kreeess
we have almost the EXACT setup except i have a 228/230 with .615 lift on a 114lsa what numbers are u pushing on yours i have yet to dyno mine. and i agree i think its a perfect street cam, big enough and not so small
Old Oct 16, 2013 | 08:56 AM
cammedvette
Never had it dyno'ed... The guy that did my street tune is very versed in the LS platform. He says with all the mods I have and the tune he installed he thinks it should be in the 415 to 420 RWHP. 480 to 485 at the crank. I would say that should be close with my mods, but you never know until you actually dyno it!
Old Oct 16, 2013 | 09:29 AM
Kreeess's Avatar
Kreeess
Funny you say that cause my tuner says the same thing and he tunes LS' all day also! I guess well never really know till we dyno, I'm actually scheduled for dyno end of nov I'll keep ya posted to give u an idea
Sent from my iPhone
Old Oct 16, 2013 | 08:47 PM
  #33
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
If you plan to drive around at 4000-6000 rpm all the time, then a big cam is what you want.
If you want TORQUE for the street, then a medium sized cam is best.
My LS6 build focused primarily on TORQUE.
I'm at 471/441 to the rear wheels now.
Perfectly drivable, and not hard on the springs.
No surging or other issues you see on big cams.
Just my opinion.
Good luck on your build !
Toque
Old Oct 17, 2013 | 09:05 AM
  #34
cammedvette
Just my opinion.
Toque
What up Toque! Always liked your ride. So what size cam do you run?
What do you consider a large cam and a medium sized cam? Seems if you go with a cam on the large side of medium you can grab some of that low end torque back with the long tube headers? Curious what your overall setup is to achieve the 471/441...
Old Oct 17, 2013 | 09:19 AM
  #35
Toque's Avatar
Toque
Doing well here ! Thanks !
2004 Z06 - LS6 Motor
Vararam
Air Bridge, smooth tube
LS2 TB (ported by Spin Monster)
Fast 92 (ported by Spin Monster)
AFR 205 heads milled to 59cc (>11.1 compression)
921 springs
LG's G5X1-E Cam (Lift 590ish / Duration 230ish / Lobe Sep 114)
LG Pro headers (1 3/4 primaries). With high flow cat's
GHL Bullets.
Toque
Old Oct 17, 2013 | 09:30 AM
  #36
Kreeess's Avatar
Kreeess
Doing well here ! Thanks ! 2004 Z06 - LS6 Motor Vararam Air Bridge, smooth tube LS2 TB (ported by Spin Monster) Fast 92 (ported by Spin Monster) AFR 205 heads milled to 59cc (>11.1 compression) 921 springs LG's G5X1-E Cam (Lift 590ish / Duration 230ish / Lobe Sep 114) LG Pro headers (1 3/4 primaries). With high flow cat's GHL Bullets. Toque
This is a simple yet very effective set up ! I like this setup also! Hopefully one day I can imitate or even come close to it!
Sent from my iPhone
Old Oct 17, 2013 | 04:46 PM
  #37
cammedvette
Vararam
921 springs
GHL Bullets.
Toque
Very nice setup... I see from your mods that you are pulling the extra hp's from your fast 92 and mostly those ARF heads. Good strong and reliable setup you have there!
To Modifications
Old Oct 17, 2013 | 07:59 PM
  #38
Toque's Avatar
Toque
Sent from my iPhone
Thanks guys.
Its been a fun, reliable setup for me.
That was my goal.
I don't need to be the fastest guy on the block.
I built my car like "I" wanted it to be.
Cammedvette:
I have been told the same that the AFR heads are a big part of the gains. They flow very well.
I gained 20rwhp and 15wrtq from the Fast 92/LS2 TB.
Toque
Old Oct 18, 2013 | 08:47 AM
  #39
cammedvette
Thanks guys.
That was my goal.
Cammedvette:
Toque
I looked into the Fast while doing my build but I couldn't afford the AFR heads like I wanted!! The Fast will not gain me near that much when paired with the LS6 heads I went with. Got a killer deal on brand new never used LS6 heads, and really liked the idea of "factory reliable power". Like you I don't need to be the fastest on the block, but I have found there aren't many faster around me!!!
Old Oct 18, 2013 | 10:22 AM
  #40
Kreeess's Avatar
Kreeess
