[Z06] alignment after lowering
Old Oct 16, 2013 | 08:13 PM
93civEJ1's Avatar
93civEJ1
Default alignment after lowering
So I took my car today to finally get aligned. Getting ready so I can go to the vette expo this weekend. Got there and put on the rack. What do ya know, its pretty much in spec. There was only one wheel that needing a slight slight adjustment. So after adjusting the one small caster on one I was on my way. What are the odds of having a good alignment when going even after lowering??
Old Oct 16, 2013 | 09:47 PM
Supercharged111's Avatar
Supercharged111
That's what I found too.
Old Oct 17, 2013 | 07:06 PM
93civEJ1's Avatar
93civEJ1
awesome. Does that happen pretty often with these cars?
Old Oct 17, 2013 | 07:21 PM
Supercharged111
An inherently good design ensures minimal bump steer if you're in the suspension's sweet spot. This car is designed to operate at low ride heights, that's why. You should have gained static camber, did you?
To alignment after lowering
