[Z06] OE lug nut lock key???
Old Oct 17, 2013 | 01:10 AM
sierra1's Avatar
sierra1
Default OE lug nut lock key???
I recently purchased my 2002 Z and did not get a lug nut lock key for the OE wheels. How can I get a replacement key? Is there a lock key number somewhere I should look for? I was digging through the owners manual/case, and found two small pieces of paper with numbers/letters on them. Would someone mind sending me a pic of their key lock number so I can see if what you have is one of the papers I have??? I'm needing to pull the wheels off and really don't want to destroy 4 sockets doing so.
TIA
Old Oct 17, 2013 | 05:04 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Are you sure you need a lug nut lock key? When I bought my car I couldn't find it either. Turned out that the previous owner had put in chrome wheels with regular lug nuts.
Old Oct 17, 2013 | 11:34 PM
sierra1's Avatar
sierra1
Yes, most certain.
Old Oct 17, 2013 | 11:57 PM
ZeeOSix's Avatar
ZeeOSix
Did you look all around in the back trunk area ... there was supposed to be a special place back there to store the lug nut key.
From the Owner's Manual:
Using the Wheel Lock Key
If you have a Z06, the wheel lock key sits in a small
depression in the trunk rail on the left side, underneath
the carpeting.
Old Oct 18, 2013 | 12:00 AM
sierra1's Avatar
sierra1
the carpeting.
I did...notta.
Old Oct 18, 2013 | 12:02 AM
sierra1's Avatar
sierra1
I did find a small tag in the bottom of my owners manual case that has the code S234K. I just emailed MacGuard asking them if this might be a key code.
Old Oct 18, 2013 | 10:51 PM
lazerfitch's Avatar
lazerfitch
Default Wheel locks
I have a '02 Z06. My lock key is on a card that says "Amcor" with red numbers 0701609 at the bottom of the white card. Hope this helps.
Old Oct 19, 2013 | 08:36 AM
sierra1's Avatar
sierra1
I found the same bag in my trunk with 4 regular lug nuts, however the white card with the key code is missing:mad I called Amcor and spoke with a rep. She said I have to take a super high res pic and email it to them, they will blow the pic up, and hopefully be able to identify the lock spline pattern. Errrrrrrrrr!!!
Old Oct 19, 2013 | 02:51 PM
ZeeOSix's Avatar
ZeeOSix
^^^ I think if it was me I'd just do whatever it takes to get the old ones off and go get some new locks. Mostly if you need to get the tires off now.
Old Oct 21, 2013 | 07:34 AM
sierra1's Avatar
sierra1
I must admit though, Amcor has been super helpful in trying to id the lock and provide me the correct key. If worse comes to worse, I'll jam a deep socket on there with a BFH, and get them off that way.
To OE lug nut lock key???
