Stalling problem
Old Oct 17, 2013 | 09:51 AM
no01k's Avatar
no01k
Default Stalling problem
Recently have had a rough idle when sitting at stop light.....runs fine does not miss when driving....then now when I just started it started fine and idled ok but when I put in gear it stalls out.....
Old Oct 18, 2013 | 04:22 PM
no01k's Avatar
no01k
Car is automatic.....no pull key and wait notice. Took it out for spin today....ran fine...not problems
Old Oct 18, 2013 | 04:23 PM
no01k's Avatar
no01k
of course it may be like a tooth ache when you go to the dentist.....!!!!
Old Oct 18, 2013 | 05:23 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Could be the ignition. Mine would stall when stopped, and sometimes when I made a left hand turn
Old Oct 18, 2013 | 05:40 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Stalling or rough idling on occasion could be an early indication that your alternator is headed south. Checking your spark plugs and wires would be good idea as well. When's the last time your fuel filter was replaced?
Old Oct 18, 2013 | 11:48 PM
Dcollins3208's Avatar
Dcollins3208
Literally just went through something similar and diagnosed that the MAF was toast. I did check EVERYTHING before getting to the MAF. Spark plugs, wires, vacuum lines, cleaned the MAF, etc. Good luck hope you're able to find the issue soon!
To Stalling problem
