[Z06] Default code help
Old Oct 18, 2013 | 07:25 PM
trj3's Avatar
trj3
Default Default code help
Thought I might try the forums first. Got the " Service active handling" code today. Checked my codes and saw
P1571 - ASR desired torque
P1689-delivered torque circut fault
B2723 Pass key detection circut
C1288 Steering position sensor unit
C1277 TC malfunction
I just bought the car with no service history. The passenger side door unlock does not work. Everything else seems fine.
Does it need to go to the dealer or is this something I can run down myself?
Old Oct 18, 2013 | 07:56 PM
OneCylinder's Avatar
OneCylinder
St. Jude Donor '13
From what I've been reading on this forum, the steering position sensor unit is where you should begin. A bad SPS will cause TC malfunctions.
Good luck
Old Oct 19, 2013 | 04:52 PM
OneCylinder
St. Jude Donor '13
You may get better response over on C5 Tech & Perf.
Old Oct 19, 2013 | 04:55 PM
trj3's Avatar
trj3
Thanks I will check it out.
To Default code help
